Old 10-15-2002, 11:33 PM   #1
e46it
e46it's Avatar
how to remove the front bumper
The front bumper is secured in three places, the front, the underneath edge and the rear edges :
1) - lever out the long black plastic trim strip that is on the right of the number plate and theshort one on the left of the number plate. Behind each of these you will find two nuts that need undoing using a 13mm socket.
2) - In each wheel arch at the front is a further screw that secures the bumper to the body, turn the steering wheel to full lock turning the wheel inwards for the side you wish to undo, e.g turn the wheel left to do the righthand side.
3) - Underneath the bumper at both ends is a triangle shaped piece of plastic held on by 3 screws that needs releasing from the front edge of the bumper.
Once these have all been done carefully pull the bumper forwards until its free. WARNING If the bumper painted do not put it down on concrete or gravel as it will take the paint off so either put it on some grass or onto cardboard
2004 BMW 325i Touring SGM
2005 Suzuki GSXR 1000|1992 JDM Civic SiR RHD Black
2000 BMW M5 Avus Blue (GONE)
2002 BMW 325i Touring TVM (GONE)
1994 BMW 325i Saloon Black (GONE)
e46it is offline   Reply With Quote
Old 01-05-2008, 04:48 PM   #2
Dr. Flyview
Formerly Flav_cool
Dr. Flyview's Avatar
Send a message via MSN to Dr. Flyview
What if you got fog lights? Pull them out and disconnect?
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
sold
Dr. Flyview is online now   Reply With Quote
Old 01-05-2008, 06:00 PM   #3
JUICY J CAN'T
propr'one's Avatar
just disconnect the wire, there's no reason to remove them.
Old 02-06-2008, 07:46 PM   #4
kòózy
6th Gear Newbie
Sounds easy from the steps you listed.....is it as easy as it sounds for someone with little experience?
- 2012 135i
- 2012 128i *retired
- 1998 318is *retired*
kòózy is offline   Reply With Quote
Old 02-07-2008, 03:11 PM   #5
Dr. Flyview
Formerly Flav_cool
How can you disconnect the wire without first pulling them out?
sold
Old 02-07-2008, 09:56 PM   #6
Mickey Knox
putting it back on?
is it just as easy to put it back on? sounds stupid but i always heard that it takes experience to put it back on so it looks right, i just cant figure out why that would be as it seems straight forward. what about new bumpers?
Mickey Knox is offline   Reply With Quote
Old 02-09-2008, 12:12 PM   #7
kòózy
6th Gear Newbie
Anyone know the answer?
- 2012 135i
Old 02-13-2008, 06:07 PM   #8
rlim
Below the bumper, there are triangle brackets at each end of the bumper which you can easily remove. Once removed, you will have access to the back of the fog lamps which you can easily disconnect the cable.
When assembling the bumper, the bumper will merely slide into the bumper mounts. You'll see the mounts at each end of the fender. When you slide the bumper in, tighten the bolts situated at the front of the bumper snug where you can easily move and align the bumper until you're satisfied with the position. Once you're satisfied, tighten he bolts. You can then proceed to plug in the fogs and assemble the triangle bracket beneath the bumper. Hope that helps!
rlim is offline   Reply With Quote
Old 10-11-2008, 08:18 PM   #9
Blown M3
I can tell you that after you remove the front bumper it will never be tight again unless you use new hardware.
Blown M3 is offline   Reply With Quote
Old 02-03-2009, 09:47 PM   #10
Davis
removing front bumper
the fastest way is to let your son drive the car into a snow bank - this works best if he carries some speed into a turn and approaches the bank from an angle - if possible the snow bank should be solid ice, otherwise hand removal will be required to complete the work.
Used parts are available at a premium
Davis is offline   Reply With Quote
Old 02-11-2009, 12:13 AM   #11
Randy
Randy's Avatar
Hahaha, Sadly I feel Davis speaks from experience.
Randy is offline   Reply With Quote
Old 02-20-2009, 01:44 PM   #12
Big T
94 318is
For a second I thought you were my father.
Big T is offline   Reply With Quote
Old 02-20-2009, 09:07 PM   #13
Davis
OH NO - not another son!!!
sorry --- no more low mileage Ti"s , in beautiful condition left to wreck - NOT WHAT??? - OK - there are lots of 3i8's left - I'll buy one tomorrow - go nuts!!
Old 03-31-2010, 11:49 AM   #14
Dysantic
Captain Chaos
Dysantic's Avatar
Anyone know of a more in-depth DIY for taking off the stock bumper and replacing it with a M3 one? I'd prefer one with more pictures if possible. I don't want to get halfway through it and then get stuck. lol
Dysantic is online now   Reply With Quote
