Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 06-16-2005, 04:13 AM   #46
Originally Posted by Axxe
How are ASA's quality wise? I have a friend who is considering EM9's for his MK3 golf, 17" x 7" Are they heavy, buttersoft wheels like TSW's or are they decent quality?
ASA is licensed by BBS, should be very strong wheels.
Old 06-16-2005, 09:03 AM   #47
Acidblast
Acidblast's Avatar
Originally Posted by Mystikal
They'll fit with spacers, those tires are bigger than ideal though (you may get into fender liner issues). You need to find out the offset for me to tell you what size spacer, though.
Mystikal, what tire size would be ideal for 18" then?
"Ooh, they have the internet on computers now" Homer J. Simpson
Acidblast is offline   Reply With Quote
Old 06-16-2005, 09:55 AM   #48
215/35/18 or 225/35/18.
Old 06-16-2005, 10:21 AM   #49
Acidblast
Acidblast's Avatar
so with that size I won't have any speedo errors? on a side note do you think 18" are too big for an e30?
Old 06-16-2005, 01:24 PM   #50
Acidblast
Acidblast's Avatar
Mystikal, those ASA AR1 18" have an offset of 38mm.
Old 06-16-2005, 05:28 PM   #51
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
If he gets the deal he says he's getting, I may be rolling with ASA's.
Old 06-16-2005, 05:47 PM   #52
With either of those tires, you will have less than 1% speedo error (up to 3% is considered normal deviance). I think to pull off 18's you need some sort of aftermarket bodywork, on my car for example they would look a little big. I really like those particular ASA's though, I'd buy them. Be very careful though, Minis have a slightly smaller centrebore than E30's, so if those wheels are made to exact Mini spec, they WILL NOT work an on E30. Contacting ASA or even Tirerack will get you a firm answer on that, ask them for the centrebore measurement. It needs to be at least 57.1mm.
You will want 15mm H&R hubcentric spacers, with longer bolts or a stud conversion.
Old 06-17-2005, 08:53 PM   #53
gsbadbmr
18's on a REALLY low e30 with a bodykit look good. I was running 18's on my e30 but found them too small (my car is really dumped) so i am now running 19's and they look and ride amazing...smoother than you could ever imagine.
-gsbadbmr
gsbadbmr is offline   Reply With Quote
Old 06-17-2005, 09:42 PM   #54
Axxe
Axxe's Avatar
What is the biggest spacer available? I'm hoping there is a 18mm hubcentric spacer, because that would bring an ET40 wheel right to ET22 which should let me run wide tires.
Old 06-17-2005, 10:04 PM   #55
gsbadbmr
You can get H&R spacers in the following sizes:
5mm
8mm
15mm
20mm
25mm
-gsbadbmr
Old 06-17-2005, 10:33 PM   #56
M50E30
www.bmwclub.ca
M50E30's Avatar
Mini's have a 56.1mm centerbore. Those wheels are probably have a big centerbore since ASA are a lower end wheel.
But if they are too small a machine shop can easily take out 1mm without problems.
Old 06-18-2005, 01:35 PM   #57
flyrawk
hello..just want to asking...i have a bbs rs 020 16x7.5 et30..i might sellng them after perfectly done....will them fit e30 m3? they're in 5 lugs, b4 im buying them from bmw shop and they said it will fit bmw's car..but i maybe no doing a 5 lugs conv on my e30 and maybe selling them...hope somebody can help me
flyrawk is offline   Reply With Quote
Old 06-18-2005, 08:04 PM   #58
The geometry is right, as long as they are 5x120 they will fit on an M3 just fine.
Old 06-19-2005, 01:03 AM   #59
flyrawk
anybody have fit this bbs rs 020 into ur's m3??
Old 06-30-2005, 02:54 PM   #60
Acidblast
Acidblast's Avatar
Hi I am really interested in purchasing a set of ADR M-Classics. I have an '86 325e with a 4x100 bolt pattern.
ADR M-Classics
17"x7.5 or 17"x8.5
offset 45
I was wondering would this fit on my car? Would i need spacers? And what type size tire would you suggest to run with these rims?
PS. if hot linking isn't allowed i'll remove the pics and host them myself.
