05-19-2005, 04:53 PM
#16
Car: S54
Originally Posted by bmwm5lover
205 50 16 I believe is pretty accurate, or 205 55 16
On a side note, AWESOME thread for us e30 guys (not that I need it anymore).
205/55/16 has a very high chance of rubbing the shit out of front fender liners, and rubbing in the rear with anything but a very stiff suspension. Do not run those.
And you need to stop hiding and tell us what you put on your car!
05-19-2005, 07:57 PM
#17
Car: 86 325es b25
Any suggestions on what I should run though?
05-19-2005, 08:38 PM
#18
Zee Frog.
Car: 328is
As Jay said, 205/50-16 or 225/45-16, with the correct offset. The 205's are safer since you don't know your rims' offset. I have 215/45-16's on my 16"X7.5" wheels, with an offset of ET25. No rubbin'. They're a bit smaller (in height) than stock, but it's hard to notice. If you get tires and there is rubbing, you'll need spacers.
Did you look closely on the inside of the rim to see if there is an "ET" offset stamping?
EDIT: I re-read your question and I'm not sure if you're asking about tire size again or tire brand.
05-19-2005, 11:51 PM
#19
Car: 86 325es b25
I'd leave it to a wheel shop, you need a very precise meter. What wheel is that, sounds like those ACS replicas on sale here a while back (16x7.5" 4x100 wheels are rare, I'm just guessing here).
You can run 205/50/16 for sure, or if the offset is ET22-ET27 you can run a 225/45/16, which is better for obvious reasons. If I were you I'd mount a 205/50/16 (used one, cheap/free from a shop) on one wheel and try it on the front and rear of the car, just to see if you need spacers at all.
Shit man extremly sorry I must have missed your post. You must have a good memory to remember those rims and yes you are correct those are the ones I am talking about.
I double checked the wheel like Al told me and all I could find was a 16-. Not sure what it is. It doesn't say et anywhere on the wheel.
I didn't even think I could run a 225 for fear of rubbing I was only hoping of running a 215/45/16 if they had it in the tire I wanted (Fuzion Zri Im on a small budget) or a 205/45/16 which I know they will have. Thats a good idea to get a cheap tire and see if it will run without rubbing but I doubt I will be able to find a free tire in a 215/45/16. Anyways thanks for all the help man I really appreciate it.
-Jesse
05-20-2005, 07:05 AM
#20
Zee Frog.
Car: 328is
If you're going for a 205 width, you'd be better off with a 50-series tire rather than a 45. The 50-series will give you just about perfect stock size. The 45 will have a smaller diameter and give you inaccurate speedometer readings. They won't fill the wheel arches as well (that's just esthetic, though) and will give you a somewhat rougher ride (because there's less "cushioning").
05-20-2005, 03:02 PM
#21
Car: is not a real ///M5
I've got the Firestone Firehawks GTA 205 50 16, very happy with them (Size/tire). Perfect size, and handles amazingly, and I think the speedo is pretty accurate, so that's a size I wsould recommend.
www.enthusiastauto.caContact if you are looking for a car
His--2000 BMW ///M5 .:Jet Black on Black:. Individual - Style 65 Wheels; 9.5" Square Set up;275 Tires;10mm/3mm Spacers; Black Kidneys;Muffler Delete; 3.5" Dual Tips; Beast Power Sway Brackets; "Dinan" Ducts; E60 SSK; BC Coils
Hers--2000 BMW ///M5 .:Avus Blue on Grey/Black:. '01 Exterior Upgrades; E60 SSK
05-23-2005, 06:34 PM
#22
Car: NEW RIDE!!! A black 325I 1989
I run my TSW wheel with 205-50-16, 225/45 16 also fit.
my wheel are ET20! no spacer. perfect fit
Ohne dich zähl ich die Stunden ohne dich
Mit dir stehen die Sekunden
Lohnen nicht
05-24-2005, 12:38 AM
#23
Car: M3, GSX-R 750, Civic
Here is my rim problem.
I personally want to pick up a set of Ronal LS down the road. I've noticed that all cars with Ronal LS have the rear tucking tire, while the front isn't (finger gap).
Currently i have Bilstein Sport and Eibach Sport Springs, but i want to swap out my Eibachs in the front for lower springs because i can't stand the look of having the rear with less gap (less than a finger) while my front has two fingers. The car is level, drives fine, but i just can't stand the difference. Plus if it was perched a tiny bit it would look awesome. Now i am just not sure if i'd able to fit the Ronal LS up front. They seem to be barely clearing the fenders.
Also, what is the best tire size to run on a Ronal LS?
This is how low i want my front dropped, will the LS still fit/work?
05-24-2005, 12:42 AM
#24
Here is a pic of what i am talking about!!
If you notice the front doesn't look like it would clear the fender if it was lowered another inch. That's pretty much the same drop i have on my car now, and i just want to eliminate the front wheel gap, but i am scared of constant rubbing or even not being able to fit the wheels.
05-24-2005, 12:57 AM
#25
Car: S54
That's because most E30 spring setups (both aftermarket and stock) make the rear of later-model cars (88+) look lower than the front because the quarter panels come lower than on earlier cars. It's an illusion.
Leave the springs and add thicker rear spring pads to even it out. BMW sells 10mm ones, they will give a ~16mm raise of the rear, enough to get rid of most of the uneven gap. I personally have a raked setup with my Ground Control coilovers, and it looks better to me (I'm not a fan of tucking at all).
Best size tire is 225/50/15. 205/55/15 will also work, but wider is generally better. Ronals with 225's fit on VERY low cars, but spring/damper rates and if you're willing to get the fenders rolled are also key.
Also, in that last picture you posted, those aren't Ronals at all. Those are BBS RZ's, old school wheels that haven't been produced in many years. They are ET20, so yes, they do actually stick out quite far.
05-24-2005, 01:02 PM
#26
Car: 86 325es b25
Mystikal any chance that this is the offset of my wheels?
Thanks again
Jesse
05-24-2005, 05:56 PM
#27
Car: S54
Thanks again
Jesse
No, that is only the rim diameter. Seriously, unless those have some ungodly deep dish, they will work 205's and some sort of spacer. Get the tires and see if you need them.
05-24-2005, 11:28 PM
#28
Car: 86 325es b25
Alright man thanks a lot for all the help.
05-30-2005, 11:58 PM
#29
Car: E30 M3, E30 332is & E36 M3
225/50/15 fit on the Ronals without any rubbing. There is no need for fender rolling. They are very tight on the front strunt, as well as the rear lip, but they clear fine. I'm runing Eibachs and Bislteins, but it shouldn't make a difference as to what you run. I have pics at ww.cardomain.com/id/iannfld if you want to see how it sits.
05-31-2005, 08:39 AM
#30
Car: S54
Correction, not all 225/50/15 are created equal, and not all fit without spacers (they rub the front strut). This includes the Bridgestone Potenza S-03 and other tires that run a similar 9.4" of section width. Popular choices that do fit include the Yokohama ES100 and Falken ZE-512, but in general the more aggressive tires (those that run wide, in addition to generally more sporting characteristics) will not fit the Ronal LS ET25 without touching the front strut.
