Old 01-31-2004, 10:05 PM   #16
paul
i pm you back
paul is offline   Reply With Quote
Old 02-01-2004, 06:14 PM   #17
328is_Perf
cool info E46_Lover ...
can the Dinan Software for supercharger do the trick for the ECU?
and the reason im not looking into supercharging is that that costs a whole lot more ... im looking at spending maximum 3,000 USD
The ONE and ONLY TRUE ///M3:
E36 ///M3 GTR
328is_Perf is offline   Reply With Quote
Old 02-01-2004, 06:46 PM   #18
djcontra
Gets Blown Daily
djcontra's Avatar
just buy the kit, and let us all know the results
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 02-04-2004, 04:07 PM   #19
97 Z3 2.8
O.K.- Brass tax time....
1. ECU controls fuel: True, but the second system listed on this site uses a piggyback and second set of injectors to supply the fuel. This works, but it's a hack. What really needs to be done is re-engineering the fuel maps, and larger (30 to 36lb) injectors. The timing would also need to be fine tuned to prevent detonation. Without proper fuel supply, yes it will be lean.. then pop- time for a new lump.
2. Diesel compression small- Untrue. Diesel's commonly run on 20:1 compression. My old TDI Jetta ran 22:1 compression. Diesel is just predetermined detonation. Turbo helps the effiecieny and torque of a deisel, but it is not required to run.
3. Intercooler not needed: True, dependand on boost. As boost levels rise the temperature also rises. It is positive for any turbo system to have an intercooler, the bigger the better. A lower temp intake charge is always preferred. So, on a low boost application you may be able to get away without one, but having one will only make your system more complete.
4. Pre tuned ECU on Benz TD. Yes, the factory system is optimized, but this system was not added as an afterthought- it was designed as part of the original car at the time of manufacture. When you add power to any engine, wheather it be normally aspirated or forced induction proper tuning is necessary. Ever put pipes on a bike or sled?
Dinan SC SFW- No this will not work. The best cheap system is A, used AA system or B, RMS with AA tuning. I wouldn't suggest to anyone they buy this system. It's a cheap hack, and as djcontra stated you'd end up replacing, and improving this system so much that you'd be better off doing it right the first time.
Bill
Bill
1997 Z3 with N/A power adders....
97 Z3 2.8 is offline   Reply With Quote
Old 02-04-2004, 09:52 PM   #20
328is_Perf
There's exactly what i wanted to hear.... good logical info
E36 ///M3 GTR
