01-29-2004, 02:40 AM
#1
Car: Bostongrün Metallic 328is
E36 Turbo KITS ... CHEAP!!
I found this ... whats you all's opinions
Turbo kits for stock engines
323,325,328
http://www.turbo-kits.com/325_turbo_kits.html
M3 .. OBDI 3.0 (maybe works for 3.2 also)
http://www.turbo-kits.com/m3_turbo_kits.html
I'm really considering buying one of these kits ... opinions???
how fast will my 328is be after the extreme turbo conversion?
01-29-2004, 03:06 AM
#2
Car: AA S/C E46 M3
t25 turbo? haha u;ll be fully spooled at IDLE..that turbo is tiny as my hand..i can get one for like $125..its basically a stock mitsu eclipse/eagle talon turbo...
Authorized Ontario dealer for Active Autowerke|VF-Engineering| AFE| Bilstein Suspension| H&R Suspension| KW suspension| Brembo Brake Systems| Stoptech| - Call us for the best pricing
01-29-2004, 03:09 AM
#3
Car: 1997 Jetta GLX VR6, 1998 BMW E36 323is {M52}(SOLD!), '04 e46 325iT (pops), '86 e30 325e {M20}(My Classic),
mitstubishi turbo's are nice when they work. My friends stealth Twin Turbo had both Turbo shot at 110,00kms.......
Past: 1998 323is (E36)
1986 325e (E30)
Present: 1997 Jetta GLX VR6
2004 325iT (E46) (pops)
01-29-2004, 03:10 AM
#4
Re: E36 Turbo KITS ... CHEAP!!
No 323 turbo kits...........
1986 325e (E30)
01-29-2004, 06:18 PM
#5
Car: Evo 8
you beter know what you are doing when installing a turbo kit, there is also engine management to think about(ECU) fuel/timing in the key factor, or else KABOOM
01-29-2004, 06:34 PM
#6
Car: 1971 BMW 1602
You bet
You can't just slap one of those on your lump without dealing with the above mentioned as well as compression.
01-29-2004, 06:39 PM
#7
Car: AA S/C E46 M3
i think an M50 can handle about 8psi of boost...but a thicker head gasket puts the compression down a bit, which u should do at least
01-29-2004, 09:34 PM
#8
How about the M52 engine? 328is...
The ONE and ONLY TRUE ///M3:
E36 ///M3 GTR
01-29-2004, 10:33 PM
#9
Car: Z3, M3 (e36)
328is_perf... you need proper tunning... that's worth at least a 1/4 of the price that you pay for a good, solid kit... I just ordered an AA supercharger kit for my z3 2.8 (97). It's being custom tunned by AA for the M50 manifold, M3 cams, headers and exhaust! Otherwise you'll end up putting in too much air and thus running lean which will blow up your engine. I ended up paying around 5K USD, though I could have bought an untunned vortech kit for 3,500 USD and spent a good 800 USD for software (AA) and another couple hundred on dyno time.
If you want to do things properly you need solid and reliable tunning. That's why the kits are so expensive in our situation. I believe the key phrase is "big power, reliablity, price - choose 2"
Best regards,
Best regards,
T.
T.
01-29-2004, 10:48 PM
#10
Gets Blown Daily
Car: 1994 333HP Supercharged Project E36, 1996 Hummer H1
the kit is designed to run without software it looks like. At 6psi, you shouldn't really have a need to change the software anyway (heck, that's what I think I'm running at without any software upgrade) All you need is a fuel management unit to piggyback until you run some higher boost.
I wouldn't spend a dime on the kit shown though because it looks like you'll end up replacing most of it with new parts anyway (like a bigger turbo, better piping, ecu upgrade, etc etc etc) which will cost thousands more ontop. You might as well just buy a proper kit. Sometimes I wish I bought a properly tuned kit because I am spending at least a couple grand more ontop of what I paid for my s/c kit just to get it working efficiently. Regardless of the extra cost though, in the end it will out perform a stock AA supercharger kit.
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
01-29-2004, 11:47 PM
#11
Car: moped
from what i know so far buy a aa kit. i love mine
01-30-2004, 01:27 AM
#12
Car: AA S/C E46 M3
u got an AA turbo paul? check ur pm
01-30-2004, 06:47 PM
#13
Car: 318is
what about the 318is 4 pots?
Join my new site now!
www.bmwz.co.uk
01-31-2004, 06:44 PM
#14
ok.... here's my summary... I dont want to put more than 8psi ever... i dont want to change internals... i just want something to put onto the stock engine....
and i dont want to spend more than 3000 USD.... is it possible?
little turbo means less turbo lag...
Yet i dont get why u have to do so much tuning to it... is that just messing with the boost and fuel?
i dont want to get too complicated... lets see a 1984 MB 300SD turbo diesel (my dad has one) doesnt have all these and im willing to bet its running at least 6psi.. whats the big difference
E36 ///M3 GTR
01-31-2004, 07:42 PM
#15
Car: AA S/C E46 M3
u need tuning because, with a turbo ur going to be pushing more air into the engine, now what controls the amount of fuel? the ECU..so u need it reprogrammed to add the proper amount of fuel, to the amount of air that goes in...so u maintain a bigger version of ur previous a/f ratio...having more air and less fuel will cause ur engine to run lean, thats why u tune it.
your saying ur dads turbo diesel doesnt have all that? well think about it..without the turbo raising the compression, the diesel's compression is small..it NEEDS to the turbo to run normal, it doesnt have a big intercooler cuz u dont need one, and then it DOES have a tuned ECU, but mercedes has these pre-programmed like any other ECU for their cars.
no more than 8psi ever? trust me...u will have 8psi..then get bored of the power, like your bored of your current power. if you want something with no lag, and less maintance, get a supercharger.
