01-26-2004, 03:02 AM
#1
Car: 01 330Ci
E36 Window Problem
Just got a 96 328 Cab, and you know when you close the door
the window move up an inch, and when you open the door it goes down, that works fine, but my problem is this constantly moves moves up and down while i'm driving???
Any suggestions????
01-26-2004, 03:11 AM
#2
7th Gear Member
Car: 335I
break it and it wont happen again
01-26-2004, 03:21 AM
#3
Retired MaXmember!
Car: 320i to 332i
Does this happen all the time?
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
01-26-2004, 04:40 PM
#4
///MMMM VIDA
Car: E36 325iS
check the little switch...its on the door latch attached to the car...maybe its lose and wiggles while u drive causing the window to go up and down
UNDER CONSTRUCTION
01-26-2004, 05:38 PM
#5
Car: 3 serious
well that happened to me once when i didnt close my door good.
01-26-2004, 06:38 PM
#6
Car: e36 m42
do you interior lights flash on / off too?.. if so, it's the door sensor that's probably gummed up. Otherwise I'm thinking a short in a wire somewhere?... tough for me to really say since I don't have experience with the window rollup/down feature... it's not Sedan's.
01-28-2004, 01:55 AM
#7
Car: E90
Might be the window is lacking the initialization thingy - it's got a program in the computer that senses for the anti-pinch and auto-up window.. did you disconnect the battery for any reason?
Try this: disconnect the battery for about 30 seconds. Reconnect it. Turn the ignition on. Lower the window all the way. Pause. Raise the window all the way - and when it hits the top-keep holding on the up switch for at least 5 seconds. Repeat for the other windows.
01-30-2004, 08:39 PM
#8
still wants a turbo...
Car: E24,E28M5,E34M5,E46
ohhh so thats why i always see you driving around in the middle of winter with all your windows down! It all makes sense now
e24 635csi -e28 528e/m30b34 - e28 M5 - e34 M5 - e46 330xi M
01-30-2004, 09:22 PM
#9
moderationistismingly
Car: 97 328is-02 Impreza
It's the sensor on the door latch, my friend had this same problem with this 318. If you grab the door handle and 'hold' the door closed does the window still move?
