11-30-2003, 07:31 PM
#1
Car: mz3 1998
computer reprograming
anyone knows a place I could get my computer reprogramed,I had a supercharger instaled by a guy,but didn t touched the computer I m runing about 4 pounds boost,I know I l have tochange my injectors too,I own a 2.8 z3........with intercooler!!!
THANKS
12-01-2003, 09:08 PM
#2
Car: Z3, M3 (e36)
Nice! What year is it? I've got a 97 2.8 z3...
OBD-II is not an easy system to program and it sounds like you have a custom setup... (i.e. 4 lb boost) In that case you most likely will NOT require different injectors depending on your setup. Software updates of such nature will most likely require some tunner time on a dyno (since this is a custom setup). The only place that I head does this in toronto is superchips... though I'm not sure they can do that for F/I applications. You may end up having to get your dyno's done a couple of times with a wideband A/F ratio and then send it with your ECU back and forth to ActiveAutowerke for tunning.
Your best bet would have been to go with tunned kit (ie. AA, Dinan, RMS)... Let me know how it goes... It would be interesting to hear since I'd eventually like to go down that road. For now however I stayed N/A (with M3 cams, ITG intake, M50 manifold and JC 328 cam software, pulleys and fan delete) and am putting down around 210 Whp. I will be doing a LTW flywheel and exhaust next... then maybe F/I next year (probably RMS blower with AA software or PD blower with JC software)
Regards,
T.
12-01-2003, 09:44 PM
#3
Krv Svoju Za Bosnu Moju
Car: 1997 328i
how about the prices on those?? since mine is the same engine it would be the same price as well i guess
12-01-2003, 09:57 PM
#4
Car: Z3, M3 (e36)
RMS ( www.racemarque.com) Vortech blowers are on sale right now (3995 USD for stage 1). Stage 2 is 5895 USD and includes aftercooler and more boost.
I'd probably ordre the Stage 1 with out the software (should be a bit cheaper) and then order the software from AA (since they tunned it already with the Vortech and the M50 manifold on the 2.8). This project will be perhaps March or April next year. In the mean time I'll beef up the suspension/brakes and finish the current performance mods (fly wheel and exhaust).
What do you have done on yours? For N/A stuff the JC cam kit is excellant and I highly recommend it. You basically get M3 performance for a fraction of the cost of the supercharger.
T.
T.
12-01-2003, 11:05 PM
#5
Car: mz3 1998
thanks for the info,my car is 96 z3 with 2.8 from 96,328......I want to bring up the boost to 8 psi,I should have to change the injectors too!!I had the intercooler instaled by camo tuning in montreal very nice job cost me 1800,but like I said very nice job.
12-02-2003, 01:35 PM
#6
Car: Z3, M3 (e36)
... I thought the 2.8 came out in 97?
The M52B28 uses the 21.5 lb injectors same as the 3.2L. This is good till about 275hp @ the crank. What kind of blower do you have? Can you post some details about your setup? 24 lb are the next ones up... you will need tunning though...
Thanks,
T.
12-02-2003, 03:40 PM
#7
Car: mz3 1998
I have A.T.I. procharger if u leave me your mail I will send pics of my set up...........thanks for the info!!!
12-05-2003, 08:20 PM
#8
Car: 97 Z3 2.8
You're going to need 24lb injectors without a doubt if you go to 8 psi. Superchips (Peter) is the only local canadian I know of. If you convert to OBD 1 Mark D'Silva can help you out. He doesn't do OBD II tuning though.
2.8 did come out in 97, he's swapped in an iron block M52.
How's the balance of your car given the extra 150lbs or so in the fron end?
Have you upped you spring rates to competsate?
Hey Tom-- don't forget your custom common ground system. Good for 7 rwhp on a new 350Z you know!
Bill
1997 Z3 with N/A power adders....
12-06-2003, 12:33 AM
#9
Car: mz3 1998
I havent touched the suspension sor far,and the ride is ok,didnt realy feel the difference.......but the rear tends to flex a litle too much when I floor it..........about 240 hp vs 150 stock!!!!
12-08-2003, 09:04 PM
#10
Car: 97 Z3 2.8
Are you talkin RWHP- sounds like fun!!
Bill
12-09-2003, 01:49 AM
#11
Car: Z3, M3 (e36)
 cool... can you post some details exactly what you have installed?
Thanks,
T.
T.
12-09-2003, 03:33 PM
#12
Car: mz3 1998
so far Ihave a.t.i procharger,with front mount intercooler,4 psi boost,but I l have it tuned 8 psi computer reprogramed,injectors changed,should be around 300 hp at the crank......if u want pics leave me your mail I l send it to you!!
12-09-2003, 03:43 PM
#13
Car: Z3, M3 (e36)
pm sent...
T.
T.
12-09-2003, 04:46 PM
#14
Car: 97 Z3 2.8
Eh Tom, wanna forward the pics over to me when you get them. I'm curious to have a look see as well.
Bill
#15
OG
Car: N55 E92 MSport
Interesting setup, what is A.T.I. ? Never heard of them. Pics would be nice, you too JazzM (btw, I think the 2.8 came out in '96, hence the '96 328iS that some members have).
