Old 10-23-2003, 04:01 AM   #1
Gamite
Gamite's Avatar
TV Lines Tutorial
It seems that many of you are putting TV lines in your signatures, and I've gotten a few questions on how to do it, so here's a tutorial I wrote up. I hope it helps.
This is the "proper" way to do it:
1) we need an image, here's a random image I took off my computer, resize it to a desireable size, crop, whatever.
I chose this picture of or mascot, "Empowerd"
www.gamite.net
Old 10-23-2003, 04:03 AM   #2
Gamite
Gamite's Avatar
2) Now go over to your layers window on the right, and click "CHANNELS"
Click that arrow on the top right of the window as noted in the image below. Click "NEW CHANNEL"
www.gamite.net
Old 10-23-2003, 04:03 AM   #3
Gamite
Gamite's Avatar
3) a pop up dialog will come up, click "OK"
www.gamite.net
Old 10-23-2003, 04:05 AM   #4
Gamite
Gamite's Avatar
4) your window will go black, now zoom in as much as you can (1600%)
www.gamite.net
Old 10-23-2003, 04:08 AM   #5
Gamite
Gamite's Avatar
5) Now click the line tool (1) and draw a horizontal line, it doesnt matter how long. Make sure "Anti Aliased" is UNCHECKED at the top.
6) Now, take the marquee tool (2) and select 2 pixels, one black one white.
7) Click "EDIT > Define Pattern" and type in whatever you want to call your new pattern, eg. "TV Lines"
www.gamite.net
Old 10-23-2003, 04:11 AM   #6
Gamite
Gamite's Avatar
8) now delete the white part so the image is completely black and then click "EDIT > Fill..."
9) Under contents click the drop down box and select patter. Then select the TV Lines patter in the box below.
10) Click "OK"
The result, you will get a bunch of horrizontal white lines, which is the basis of your TV Lines.
www.gamite.net
Old 10-23-2003, 04:13 AM   #7
Gamite
Gamite's Avatar
11) Now go over to the channels window that you opened earlier that you created your new channel with. "CTRL+Click" your TV lines channel.
it will look something like this. Basically, you've highlighted only the white lines. This works because you're in the alpha channel.
www.gamite.net
Old 10-23-2003, 04:16 AM   #8
Gamite
Gamite's Avatar
12) Now click the Layers tab in the same window, and go back to your image. Make a new Layer (Layer > New... > Layer).
13) Click "Edit > Fill..." But this time, click foreground colour instead of Pattern.
I find that BLACK is the most effective colour.
click "OK"
www.gamite.net
Old 10-23-2003, 04:18 AM   #9
Gamite
Gamite's Avatar
From this point on, you're pretty much free to do whatever you like, spruce it up a bit, play around, do what you like. Usually changing the oppacity on the TV Lines layer to about 30-50% is more visually appealing.
I added some depth using feathering to make it look kinda like a TV.
I hope the tutorial helps, ask whatever questions you like.
NOTE: Once you've done this procedure, you don't have to re-create the pattern anymore, just go into the alpha channel and continue on from step 8
www.gamite.net
Old 11-05-2003, 12:53 AM   #10
///Milk
BangSentra
///Milk's Avatar
Send a message via ICQ to ///Milk Send a message via AIM to ///Milk Send a message via MSN to ///Milk Send a message via Yahoo to ///Milk
thx for the tutorial Gamite...i hope it'll work for me..heheh
///Milk
2006 Nissan Sentra 1.8S
2009 Ford Focus SES Sedan
///Milk is offline   Reply With Quote
Old 11-05-2003, 03:27 AM   #11
koncise
all you need is one mike
koncise's Avatar
Send a message via MSN to koncise
Thanks man, I've wanted to know how to do this for the longest time.
One part of your tutorial threw me off a bit though... you should clarify that before doing step 8 (edit -> fill), you need to make sure to DESELECT the 2 pixels that were selected. Took me a few minutes to figure out why it wasn't working for me
koncise is offline   Reply With Quote
Old 11-05-2003, 07:14 AM   #12
Gamite
Gamite's Avatar
ok I'll fix that up.
www.gamite.net
Old 11-07-2003, 01:37 AM   #13
SpudBoy
Couped up
SpudBoy's Avatar
Send a message via ICQ to SpudBoy
personally, I've given up on the cloned-sig-mode.
an original pic + original effects = SICSIG.
Spud totes his old Win'95 lightwave 3D compatible-puter to the repair shop.
(sorry I can't afford Maya )
thanks for the tutorial Gamite
SpudBoy
'99 M Coupe - Imola/Imola
Signature Pictures by Alezone
original BMW parts
To mod or not to mod? That is the question
SpudBoy is offline   Reply With Quote
Old 11-07-2003, 04:27 AM   #14
Gamite
Gamite's Avatar
cloned sig?
www.gamite.net
Old 11-07-2003, 04:37 AM   #15
tlaselva
1800+ HP Driveway
tlaselva's Avatar
Gamite, you should have a weekly PShop tip/lesson, much like this one........
What version are u using?
2011 X5 M-Sport 3.5i
2010 Dodge Ram Hemi Sport
2010 GSX-R 750
2003 C5 Z06
903rwhp/815rwtq : 10.3@152mph
