11-11-2003, 02:58 AM
#31
Your Nightmare
Car: Bimmers
Manifold - the most important part of your turbo setup
Turbo - get one that can be water cooled
Intercooler - the biggest you can afford.
AFPR
Piping
boostgauge
Once everything is installed then you can install a blow off valve. Don't need injectors, same goes for a turbo timer.
SL
11-11-2003, 05:37 AM
#32
Car: E36 323i, E30 Racecar
I'm not going the RRFPR route. I hope the fuel pressure will be enough. I'm just going for different injectors and letting the Engine management do the rest (fear not.. it isn't bmw)
BMWs Downunder
http://www.bimmersport.co.nz
11-11-2003, 03:05 PM
#33
...Delt Smash
Car: A decent one
Does anybody here know if a 324td manifold can be mated to a dsm turbo? I really need info on BMW td setups.
11-11-2003, 07:25 PM
#34
Car: 325is 1987 Turbocharged
Miguel, a T25 if yuo have it, don't use it, it won't work with your displacement...  believe me, look for a T3/T4 with a AR. minimus of 60.....
11-12-2003, 08:07 AM
#35
do a custom manifold.. it ain't expensive.. costin me $500 kiwi..around $270 US
BMWs Downunder
11-12-2003, 11:19 PM
#36
...Delt Smash
Car: A decent one
I wouldnt even know where to begin looking for someone to make a custom manifold.
11-13-2003, 03:35 AM
#37
Any machinest could make the part that bolts onto the exhaust ports.. I have an exhaust shop making the actual pipes.. I'm not sure if every exhaust shop can do that?
BMWs Downunder
11-13-2003, 03:41 AM
#38
A rough idea friend made for me.. Not sure if one like this is getting made...
BMWs Downunder
11-13-2003, 08:50 PM
#39
Car: moped
best place to get any turbo manifold made is jr racing they bu\iuld all the manifolds for sem and altech splitfire etc. they have also made an e36 setup. right now thet are working on that blue e36 318 convertable that is turbocAHARGED THEY ARE helping me out with something
11-13-2003, 10:36 PM
#40
Car: 89 325i
http://www.proturbo.fi
11-14-2003, 06:57 AM
#41
BMWs Downunder
11-17-2003, 04:13 PM
#42
...Delt Smash
Car: A decent one
Wow, what do they charge for a custom manifold? one arm and two legs?
11-17-2003, 07:45 PM
#43
Car: bmw e30
re: diegom6
I would like to know if you put a FMU or RRFPR, because me I have one and which kind of fuel hose do you use to resist to the pressure...
and also your AFM resist to the air pressure ???
thank you
Dave
11-18-2003, 02:54 AM
#44
...Delt Smash
Car: A decent one
I contacted them... $660Usd shipped to Canada.
Not as bad as I thought.
11-18-2003, 03:11 AM
#45
Gets Blown Daily
Car: 1994 333HP Supercharged Project E36, 1996 Hummer H1
Miguel, I've seen some custom turbos where the car used the stock manifold, but had a Y-Pipe system created for where the manifold meets the main exhaust, and one side of the Y went to a turbo flange. It basically worked the same, except there was no need to modify the manifold
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
