Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 07-13-2014, 01:34 PM   #1
schumacher
FS: S52 Engine & ZF 5-spd
Was going to use on my 328is but I'm buying a house so all toys have to go.
From a 1999 US M3, last registration at 120k miles based on the VIN. Will come with matching ECU, key and EWS.
Still in the shell, starts and runs fine. Clutch slave cylinder needs replacing as it dumped all fluid and pedal went to the floor.
$1200 for the engine and $300 for the tranny. Also have E34 M5 clutch and UUC lightweight flywheel available for $200 more.
schumacher is offline   Reply With Quote
Old 07-13-2014, 11:14 PM   #2
CherryM5
what else would i need to put this in a e30?
CherryM5 is offline   Reply With Quote
Old 07-14-2014, 12:24 AM   #3
schumacher
You would need to convert to OBD1. I would also suspect you might need the propeller shaft.
Old 07-14-2014, 09:50 AM   #4
TSI
Reverse Gear Member
Need e34 oil pan too
TSI is offline   Reply With Quote
Old 07-14-2014, 09:53 AM   #5
schumacher
Right, that too
Old 07-14-2014, 11:32 AM   #6
sb_600
sb_600's Avatar
PM sent!
Shawn
Old 07-14-2014, 11:36 AM   #7
schumacher
Originally Posted by sb_600 View Post
PM sent!
All PMs replied to!
Old 07-14-2014, 11:50 AM   #8
sb_600
sb_600's Avatar
just sent another
Shawn
Old 07-15-2014, 12:14 PM   #9
frankie591
wish I had the time to swap this in place of my m52!
Old 07-15-2014, 12:20 PM   #10
schumacher
Shouldn't take longer than a weekend! Pull out m52, put in s52, drive, smile.
Old 07-16-2014, 05:03 PM   #11
Jeff2886
just sent another
I like where this is going
Jeff2886 is offline   Reply With Quote
Old 07-28-2014, 07:51 AM   #12
schumacher
Tranny, rear 3.23 LSD & propeller shaft sold! Just the engine, clutch and flywheel left plus other odds and bits. I have the whole car in pieces so if you need any body parts / interior parts let me know!
Old 07-28-2014, 11:27 AM   #13
87325I
E30 enthusiast
You have any compression numbers for the motor?
87325I is offline   Reply With Quote
Old 07-28-2014, 01:09 PM   #14
schumacher
Cyl 1: 176
Cyl 2: 172
Cyl 3: 175
Cyl 4: 178
Cyl 5: 173
Cyl 6: 171
Did it right before pulling the motor / tranny last night.
Old 07-28-2014, 07:12 PM   #15
haikara2308
still have the engine? if so pm me.
haikara2308 is offline   Reply With Quote
Tags
clutch, engine, m3 engine, s52b32, zf tranny
