Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 06-26-2014, 05:37 PM   #1
nate_s89
E36 M5o Stroker - Rotating Assembly, cams, WAR chip etc.
Throwing out a feeler to see if anyone would be interested in my M50 stroker. It consists of an M54 crank, M54 rods, and CP-Cariilo M54 12.5:1 pistons that are 84.5mm, cost me $1100 from VAC motorsports. With this setup and a 0.14 inch MLS cometic head gasket the car had a compression ratio of ~10.6:1. The setup has around 10,000km on it, would be looking to get $1000 for the rotating assembly plus shipping. I had the car dynoed and it made over 200hp to the wheels with the stock M50 cams and a bad tune. I was dumb and left my tuning laptop at home which was three hours from the dyno, never went back unfortunately. I also have the following parts which have the same mileage:
AA track pipe section A and B - $550
Poly trans mounts (UUC I believe) - $20
Trans crossmember - $40
S52 cams - lobes are good some wear on bearing journals, will get pictures - $300
Miller WAR Chip - $250
3.5 inch HFM - $80
Bimmerworld 3.5 inch intake elbow - $40
M50 manifold - $50
F1 lightweight chromoly flywheel, clutch, and pressure plate - $200
Freshly rebuilt Z3M shifter - $60
I will add more parts as I think of them. If your interested in something shoot me an offer. If I get a buyer for the rotating assembly then a part out will move forward. Parts will be shipped from 48152 or N8R1V7, I can ship from either the US or Canada depending on buyer location. PM is best.
nate_s89 is offline   Reply With Quote
Old 06-27-2014, 11:32 AM   #2
nate_s89
Upp
Old 08-02-2014, 02:17 PM   #3
nate_s89
Still looking for a buyer for the rotating assembly.
Old 09-04-2014, 02:00 PM   #4
nate_s89
Have decided to keep this engine until fall and part out the turbo build which can be found here. Some of the parts cross over.
http://www.maxbimmer.com/forums/showthread.php?t=164943
Old 05-05-2016, 08:40 AM   #5
KCAJOG
ill take the intake elbow if its the 90 degrees one!
KCAJOG is offline   Reply With Quote
Old 05-17-2016, 09:42 AM   #6
KCAJOG
ill take the clutch and flywheel if you still have it!
Old 10-01-2016, 11:26 AM   #7
KCAJOG
ill take the intake elbow right away if its the 90 degrees with 1 vacuum line hole. i will e transfer the money. pay and schedule shipping!
Old 10-02-2016, 04:17 PM   #8
nate_s89
Sorry everything from that build is sold.
