Old 01-08-2014, 01:00 PM   #1
Fuzzuki
No Block heaters?
My 2011 323i has not block heater?
WTF?
Fuzzuki is offline   Reply With Quote
Old 01-08-2014, 04:08 PM   #2
jrsmitchell
Switchtronic
jrsmitchell's Avatar
Most cars don't. Did you order one?
Jeff | '94 BMW Alpina B3 | '06 BMW 325XI Wagon
jrsmitchell is offline   Reply With Quote
Old 01-08-2014, 09:15 PM   #3
P90Puma
The hell do you need a block heater for?
135i started up like a champ at -25, not even a long crank.
P90Puma is offline   Reply With Quote
Old 01-09-2014, 02:20 AM   #4
jabela
I put this on my 325 a couple winters ago. Works great! Better than a block heater.
http://www.amazon.com/gp/product/B00...00_i00_details
www.maisonapothecare.ca
Old 01-09-2014, 02:33 AM   #5
A 323i that doesn't have all the options! You DON'T say! lol
Old 01-09-2014, 04:15 AM   #6
aviator
Block heaters are always optional in this part of Canada... you sometimes find them as a "dealer installed standard option" in Man. and other western prov. but generally not here unless it's a diesel and even then not always anymore...
Pad type heaters as posted by jabela above are excellent options often used on aircraft engines... however mounting surface must be completely clean and free of rust, loose paint etc. to ensure a complete, solid seal... be careful to attach the plug wire securely and away from moving parts...
aviator is offline   Reply With Quote
Old 01-10-2014, 04:43 PM   #7
Fuzzuki
It's not so much that I need a block heater. Due to my wife not driving it very far to work, the battery does not charge.
So on cold days the starter turns over very slowly untill she catches.
I think a block heater would get it going a bit quicker.
I will look into the above external heater. That's a great idea.
Here in Missisauga it was down to -21 degrees the other day.
Old 01-10-2014, 05:01 PM   #8
jabela
The main reason I got the oil pan heater was to prevent common CCV failures that are going to happen at some point, especially if you have short drives in the winter. It basically goos up your CCV system and you either get a vacuum leak, or you suck oil into the engine and you hydrolock it. Google it if you want to scare yourself.
The other benefits of running an oil pan heater is that your oil is nice and warm so less wear on the engine at startup, plus your car warms up quicker so you have heat out of your vents sooner.
The downside is you have to plug it in to work, but I have it on a timer so it only comes on in the morning an hour before I leave for work.
Old 01-10-2014, 06:55 PM   #9
windwagen
windwagen's Avatar
Aren't you using synthetic oil? Synthetic doesn't get (as) thick the way dino oil would from cold temp.
Old 01-10-2014, 07:02 PM   #10
jabela
Yea, I do, but it's still nice to have heat from your car quickly. Again, the main reason is the whole CCV issue, which happens on cars even if they're running synthetic.
Old 01-10-2014, 07:04 PM   #11
ac_2007
Cruising in Top Gear
ac_2007's Avatar
You should've seen my face when I tried installing a magnetic oil pan heater.. and then realized my oil pan was aluminum once the car was on jack stands
Old 01-11-2014, 02:04 AM   #12
aviator
If it's the short drive to work not charging the battery being the main issue you'd be better off getting a small 2A "battery maintainer" charger from CanTire... it will keep the batt. charged up and be more helpful over the long run then the block heater since constantly being under charged will kill the batt. faster then a few cold starts will hurt the engine...
Old 01-11-2014, 03:53 PM   #13
jabela
Also check your battery to make sure that the cells are full of distilled water.
