Old 03-23-2013, 09:31 PM   #1
erwin2toes
Question about aspect ratio
Hi guys,
I have a 206 750Li, and right now there are winters on them- Square setup. The measurements are 245/50/R18. I'm shopping around for summers, and I'm looking to get a staggered setup. My question is: does the aspect ratio have to be 50 for all 4? I'm not exactly sure how low I can go. Hope someone can educate me on that. Thanks!!
erwin2toes is offline   Reply With Quote
Old 03-24-2013, 12:38 AM   #2
DET1990
The aspect ratio doesn't need to all be 50 as a smaller section width would have a smaller side wall than a larger section width with a 50 aspect ratio you would want all tires to have the same height so on the rear you would probably use a 40 or 45 depending on width
DET1990 is offline   Reply With Quote
