Old 03-01-2013, 06:53 PM   #1
matty.dc
matty.dc's Avatar
Converting to OBD I with an auto harness
Hi guys,
I've bee reading post after post and I'm getting a mixed response when I look for answers regarding the auto harness. Does anything need to be modified in the harness/any wires connected to allow it to function in a manual car? I'm using a chipped red label 413 and a harness from a 93/94 325is. It's going on a 97 s52.
Matt
2013 Ford Edge - Daily Driver
Old 03-01-2013, 07:51 PM   #2
e30_kid89
The Afro-stig
e30_kid89's Avatar
Get an ETM, look up the colors and make the cuts at the splice points. If it's done right, it'll function and look 99.999% like a manual harness.
Old 03-03-2013, 04:39 PM   #3
matty.dc
matty.dc's Avatar
For others seeking this information:
In the auto wire loom that goes down to the trans, there is a brown/black wire (brown wire/black stripe). This wire has to be grounded. This wire grounds the starter relay (86pin) as if the car was in park or neutral. You can also do this right at the trans module plug, as it is the same colour and comes out of pin 26 on the trans module plug.
Old 03-03-2013, 07:10 PM   #4
cormier
cormier's Avatar
Hmm.. I remember reading this somewhere but my motor fired just fine without this modification!
Old 03-04-2013, 10:05 AM   #5
e30_kid89
The Afro-stig
e30_kid89's Avatar
x2.....I've deleted all the auto wiring without having to do that on two different harnesses.
Old 03-04-2013, 10:11 AM   #6
dcramer
what do you do about drive clean with an ODB1 conversion ?
Old 03-05-2013, 06:34 PM   #7
e30_kid89
The Afro-stig
e30_kid89's Avatar
Nothing.
Old 03-05-2013, 07:00 PM   #8
matty.dc
matty.dc's Avatar
I have an 87 so I'm exempt
Old 03-05-2013, 10:42 PM   #9
cormier
cormier's Avatar
Dope. How's the rest of the build going?
Old 03-05-2013, 10:49 PM   #10
dcramer
anyone with an S54 transplant ? emissions will be harder as the VIN's won't match
Old 03-06-2013, 07:49 AM   #11
cormier
cormier's Avatar
True, I don't think anyone is running obd1 s54s though
Old 03-06-2013, 07:50 AM   #12
dcramer
Clearly, I posted in the wrong place.... I'll start a new thread
Old 03-06-2013, 04:45 PM   #13
matty.dc
matty.dc's Avatar
The motor is all together. I just have to pull the M50 out and drop the S52 in
