02-13-2013, 02:13 AM
#1
Car: BMW X5
X5 Timing Chain snapped HELP!!
Hey there, I am new to this Forum and just bought my first beemer two weeks ago. Its a 2001 BMW X5 4.4L. Everything worked fine till we got the stupid -45 degrees weather in Saskatchewan and I tried to start the vehicle and it wouldnt start. I waited a few days till it warmed up and still nothing. I towed to a buddies house with a heated garage and let it warm up for couple hours and it now started turning over. While turning it over I heard a bang. Popped the hood and looked around and noticed a big chunk of the valve cover was near the oil cap. I looked in the hole and the chain was broken. Would this be worth fixing? The engine was not evening running when it snapped so I am hoping there is no internal damages.
02-13-2013, 02:38 AM
#2
Car: M5 Touring, 335i E92
Its not the cold, just neglected maintenance...Will happen to most 4.4's from 180 to 240K...Unless the timing chain and guides get replaced, this is what will happen even under normal conditions! We see it here every day.
IMO not worth saving this motor. Even at low RPM you can still bend valves, so chances are you need a full head job. Not easy or cheap. If not done by the right mechanic, you can run into even MORE problems, seen it more than once.
02-13-2013, 02:43 AM
#3
Car: BMW X5
Oh thanks for the advice. Now where do I get a decent priced motor? I found one in the link below. Not sure If I should risk it. I like the price on it though
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ454840501
02-13-2013, 02:50 AM
#4
Originally Posted by 2fast4ux5
Knowing the car business pretty well, i can almost guarantee no 2001 motor has 80K, unless backed by some proof! The price is amazing, but a gamble for sure...
02-13-2013, 02:59 AM
#5
Car: BMW X5
Definitely a gamble for sure. Do u have this motor in stock?
02-13-2013, 10:59 AM
#6
Car: BMW X5
Actually to think of it, I don't even know if the hole was even there before because the plastic cover was over the engine. Took the valve cover off today and it doesn't seem like the chain snapped but its loose.
03-10-2013, 08:25 PM
#7
Car: E46 touring and E39
I was wndering, they don't ususlly break, they just slap around a lot and maybe jump a few teeth doing lots of damage but break....
Have you seen one? That would take a lot more then a frozen motor to snap it
03-10-2013, 11:00 PM
#8
I have about 4 of them sitting in the shop right now, broken valve covers, sometimes damaged timing belt covers. Few cases with no compression of some or all cyl...
It does way more damage than most people think, thats why it gets neglected. If and when it goes, it could mean big engine damage...
03-11-2013, 08:12 AM
#9
It is amazing how all it takes is regular oil changes to save a lot of grief but people just don't do it.
BMW service schedules don't help....
03-11-2013, 11:53 AM
#10
Car: BMW X5
Update on my X5. Took the vehicle to the shop and they took the motor apart. The chain snapped in two places on the driver side. The plastic timing chain guides crumbled in pieces. They removed the heads and 4 out of the 8 cylinders were shot. I then bought a motor for $3000 + $1400 labour, $280 for new water pump, belts + 250.00 for shop supplies & fluids + $130 for oil pan heater. Over $5000.00 what a costly one. My worries is that it will happen again. What other regular maintnance should I do to prevent this from happening? I was told that its common for those plastic guide rails crumbles apart and you will never know cause its all internal. The best way to see is to drop the oil pan to see if theres any plastic pieces in there.
03-11-2013, 04:30 PM
#11
Wow, I take back what I said , I guess they can break...
Used motors are always a crapshoot. Could be great, could be your motor 6 months ago.
Lots of oil changes, the guides have tensioners that are oil filled, they get sludgy the chain slaps around.
03-18-2013, 02:36 PM
#12
Car: 3Series
Wow... $5000 worth of repairs.
The Truck has a wholesale value of $4800 with around 180K on it.
You might have been better off buying something else and stripping this thing for parts.
Sorry you had to go through this, just after you bought it.
Was the engine rebuilt or used for $3000?
You might want to consider driving it for the summer and selling it near winter time.
Timing chains in general usually out live the vehicle.
There are a few exceptions.... I didn't know the X5 was one of them...
Shame on you BMW... .
