Old 02-02-2013, 01:55 AM   #1
Royksopp
Royksopp's Avatar
transmission whistle???
i have a bmw e36 325is (m3 swap from 98), i just had a small leak fixed on my transmission, and had a new hanger bearing installed aswell (completely shredded). From a cold start, in all the gears i heard a whistling noise coming from my transmission, but when i clutch in, the noise stops. it seems to occur when under load. When my car is fully warmed up the noise stops. i did some research and no solid explanations. before i got everything fixed it never had made that noise.
has anyone had this problem?
thanks,
Royksopp is offline   Reply With Quote
Old 02-02-2013, 06:55 AM   #2
E36is
'OldSchool..'
E36is's Avatar
few things come to mind:
need a new clutch/flywheel
need a new throw out bearing
Old 02-02-2013, 11:40 AM   #3
Royksopp
Royksopp's Avatar
okay, ill defiantly look into that.
Old 02-02-2013, 11:54 AM   #4
Royksopp
Royksopp's Avatar
could it possibly the type of fluid used aswell? my clutch seems fine, not slipping or anything. because once my car is warmed up it goes away..
Old 02-02-2013, 12:34 PM   #5
E36is
'OldSchool..'
E36is's Avatar
dont think fluid will cause that noise.
Old 02-02-2013, 01:07 PM   #6
Royksopp
Royksopp's Avatar
i was reading on m3forum.net, and it could possibly be an input shaft bearing.
Old 02-02-2013, 02:34 PM   #7
Lurkmei$ter*
├╝berwacht Sie
Lurkmei$ter*'s Avatar
Judging by your symptoms my number one suspect would be the input bearing on the diff.
Seen this issue quite a few times.
Officer Douche Bag: " you know, I should give you a ticket for your exhaust being so loud"
Me: " In that case, shouldn't you be ticketing every Harley motorcycle you come across, surly they are louder then I am ? "
Officer Douche Bag: "Oh no, they came from the factory like that, it's obvious you modified your exhaust to make it louder, here is your ticket"
Me: "Have a great day officer"
Lurkmei$ter* is offline   Reply With Quote
Old 02-02-2013, 05:49 PM   #8
Royksopp
Royksopp's Avatar
im probably going to call RMP and have them diagnose this problem.
Old 02-03-2013, 12:00 PM   #9
5style
Hatters gon Hatt
5style's Avatar
clutchy
Old 02-03-2013, 12:33 PM   #10
JINT
JINT's Avatar
Input shaft bearing on the tranny. Get M0S2 Anti-friction paste for gears by Lubro Moly, squize it into the tranny and the noise will go away.
Old 02-03-2013, 12:54 PM   #11
Royksopp
Royksopp's Avatar
Where can you get this paste???
Old 02-03-2013, 02:54 PM   #12
nate_s89
Definitely bearing, I had the exact same problem. Mine was the counter shaft bearing though. Do you hear the noise in 5th gear?
nate_s89 is offline   Reply With Quote
Old 02-03-2013, 03:19 PM   #13
Royksopp
Royksopp's Avatar
yes i did, in all the gears. i have another transmission that i got earlier this week, if it comes down to it, ill just have the other one swapped out.
Old 02-04-2013, 01:32 PM   #14
JINT
JINT's Avatar
you can buy the paste at Automaster Trading shop. It's on 1170 Sheppard ave West, Unit 27. It's like 10-15$
