Old 02-01-2013, 07:56 PM   #1
TF3N
Cracked rear subframe? (Video)
http://youtu.be/2mNhnAgB-UU
I just started getting this noise today. I recorded the video from my phone in the trunk.
Is it the dreaded cracked subframe?
TF3N is offline   Reply With Quote
Old 02-02-2013, 02:58 PM   #2
jabela
Not sure as I don't have the issue, but it could be. I don't think it usually happens on our low power 325's.
Sounds similar to these videos.
http://www.youtube.com/watch?v=jakWlOXROJc
http://www.youtube.com/watch?v=JI-Uiy6ZcFw
You should be able to see any damage by looking under the car.
2002 E46 325ci // 5spd // Sport Suspension
www.modernapothecary.ca
Old 02-02-2013, 03:04 PM   #3
TF3N
Well, I took it to an indy down the street(not BMW specific, but seem to know his stuff). He took it for a "spirited" drive(as per my request) and immediately thought it was a rear shock mount.
We got it on the lift, and to our surprise, everything was on point.
The shocks/mounts were fine and the springs are basically brand new (replaced in August 2012).
He poked around, checked for play in the diff(there's a slow leak, checked levels, everything's fine), violently shook the rear wheels... nothing. He popped the trunk, started pressing on **** trying to get the sound to replicate... nothing. He removed the tools from the trunk mounted toolbox and then we went for a drive.
The noise magically disappeared! He thinks it was the tools in the box, I seriously doubt it as the noise was too loud to be that.
Anyways, I'm pretty relieved although very confused. The shop tech only charged me a round of coffees for the visit - pretty cool guy.
Would the noise just stop if the subframe mounts were cracked/torn? I'd think it would be a constant noise.
I've booked an appointment with the subframe specialists(RMP Motorsports) to have my diff oil replaced/flushed. They'll be inspecting the subframe at that point. I'm not quite due for a flush, but I figure $80 for the diff oil change and an inspection is well worth it. They typically charge $50 for the inspection alone.
I'll post updates on Friday after the appointment.
But do you think the noise would disappear, even temporarily, if the subframe was cracked??
Old 02-02-2013, 03:10 PM   #4
jabela
lol... I was kind of thinking something rattling in the trunk too.
When did you get the noise? Only on throttle application? You wouldn't think it would just go away like that.
You really should be able to see any cracks if you crawl under your car with a light and look at the subframe mounts.
Did the mechanic look at the subframe area? It would be pretty easy to see the damage if it was there.
Old 02-02-2013, 05:21 PM   #5
TF3N
Nothing jumped out at him, then again he wasn't a BMW specialist per se. He wasn't too up on the whole subframe ordeal, although he mentioned something abou the "recall"(class action if I'm correct).
Last night before bringing it to him I had removed the following:
Rear lower seat
Spare
Spare cover
Trunk carpeting
Battery Cover + Drivers side organizer/cover
Jack
Probably other things I have forgotten
With all of these items removed, I find it being something rattling in the trunk hard to believe. The noise in the video is quite loud/prominent.
Somebody on another forum said that the suspension being fully unloaded could have caused the rattle to disapear. Maybe a shock was stuck or something, causing the noise. This to me makes sense.
The video, although black, gives you a good indication of when the rattle was apparent. Mostly over bumps, although hard jerky throttle application would cause it too.
After you posted those images(thanks), I crawled under the car and took a look at those mounting points. I didn't see any cracks, and it's definitely not "sunken in" like that last pic - but I didn't have enough room to check all of the angles, as it was very tight under there.
I'm anxious to see what RMP says on Friday.
Old 02-03-2013, 03:26 AM   #6
ac_2007
Cruising in Top Gear
ac_2007's Avatar
You have to remove the trunk liner and cut through the black rubberized-paper grommet to fully see the condition of the shock mounts. If they're loose or defective, you'll notice.
What springs did your rears get replaced with? If they're not OEM, you can easily have a low-speed clanking noise because they'll bind. The spring pads could be installed incorrectly, off center, or otherwise causing this issue as well.
I somewhat doubt it was the tools though. The battery compartment is also an area where you could have something rattling around.
ac_2007 is online now   Reply With Quote
Old 02-03-2013, 11:23 AM   #7
TF3N
The springs are OEM, I guess it's possible they were installed incorrectly - they seemed good to me when we had it on the lift, although I am no expert on suspension.
I already had removed the battery cover, so it couldn't of been that.
I recently stuffed the rear deck with sheets, towels, etc. I'm wondering if that has anything to do with it? Maybe I cracked something by applying too much force when stuffing? I dunno.
The clicking noise was LOUD and constant... I cant see anything that was left inside of the car making that noise. Of course, I could be wrong.
Old 02-16-2013, 08:03 AM   #8
ex3mal
Weapon M
ex3mal's Avatar
http://www.maxbimmer.com/forums/showthread.php?t=154631 check this fix
ex3mal is online now   Reply With Quote
