Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 01-26-2013, 09:42 PM   #1
DR.ZED
FS: M20B25+5 speed, 173 DME, Markd Chip 19# - Complete ETA conversion
Engine can be seen running and you can drive it. Turnkey eta upgrade with custom wiring harness included for your rectangle C101 connector. Or forget the connector and use as a re and re for an "i" car. Great for a 5 speed swap, or ETA 5 speed swap from an auto!
1987 M20B25
Purchased engine from Glarner Motorsports to do an "i" swap into my eta car. Had timing belt, water pump, valves adjusted and rod bearings swapped out. The rod bearings were an easy swap since the engine was out of the car. Each oil change there is less and less break-in material. This last oil change almost nothing. Come drive it and see for yourself.
Approx 8000 kms on this engine since the install. Drop it in and GO. You will get:
ENGINE:
1987 M20B25 motor as a complete assembly with wiring harness.
Good rad hoses
New O2 sensor
Oil cooler included
New thermostat (OEM)
Recent timing belt, water pump and rod bearings
New alternator
Recent power steering pump
Recent engine mounts
Recent plug wires, cap and rotor
19# injectors
"173" DME with MarkD 91 octane 19# injector chip.
Cone intake
Full engine wiring harness.
All vacuum hoses changed
TRANS:
Good clutch and flywheel. Complete Transmission.
Rebuilt shifter (stock) with shift plate, newer guibo on transmission flange included.
Newer transmission mounts with transmission crossmember.
Smooth shifts, no grinding
$700 takes it all (deposit required, then I will pull it for you to pickup in Oshawa)
email is the key: camgolberg AT gmail.com
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 04-16-2013, 12:26 PM   #2
325man
e30 adict
Is this still available?
325man is offline   Reply With Quote
Old 04-16-2013, 07:40 PM   #3
DR.ZED
A TON of interest. I mean, I'm really surprised. By the time I found components for the 5.0L engine I ran out of winter. I really don't want to pull it now and be down a car for the summer.
This will be back up in the Fall!!!!!
Cam G.
85 325e M5
Old 07-15-2013, 07:53 PM   #4
TSI
Reverse Gear Member
Any chance you're ready to sell it again?
TSI is offline   Reply With Quote
Old 01-18-2014, 09:55 AM   #5
DR.ZED
Yes.
It comes wrapped in 4 doors.
Selling complete vehicle.
Cam G.
85 325e M5
