Old 01-25-2013, 07:24 PM   #1
whiskas
Starting problem in minus temperatures
Have a 2002 325i, it has difficulty starting first thing in the morning, I used to repeatedly crank until it started until I discovered that I can tell when it will start just by turning the ignition on and wait for a buzz noise which I assume is the fuel pump(?) once it does start it drives fine and starts no problem throughout the day up until the next morning.
It was minus 20 the other morning and there was no way it would start, eventually 5 hrs later it started and I took it into a local shop, they replaced the boots on the mass air flow sensor which were cracked and split on the underside, the next morning it didn't start.
Anyone have similar issues?
It cranks fine, all fluids are topped up etc.
whiskas is offline   Reply With Quote
Old 01-25-2013, 09:32 PM   #2
ac_2007
Cruising in Top Gear
ac_2007's Avatar
It just sounds like your fuel pump is not delivering that gasolina where it needs to be. Do you prime it by turning the key to accessory position for a couple seconds first? It makes a distinct noise.
Purchase a new fuel pump from a vendor online. This is a ~$160 fix.
ac_2007 is online now   Reply With Quote
Old 01-25-2013, 10:02 PM   #3
pawelgawel
I have a new one VDO if you need one
pawelgawel is online now   Reply With Quote
Old 01-26-2013, 09:06 AM   #4
whiskas
I think the problem is that it won't start when it doesn't prime, I have only noticed the buzz noise when it will start, don't think it is the fuel pump, it is whatever sends the signal for it to prime as when it does it starts ok
Old 01-26-2013, 09:20 AM   #5
1bmw1
That buzzing sound is an indicator that your fuel pump is working. If there are times that you don't hear that buzzing, and you clearly indicated that it won't start when you don't hear it, then i think it may be your fuel pump as well. Either that or some kind of bad connection leading to the pump?
Old 01-26-2013, 11:22 AM   #6
whiskas
Ok, I'll check out the connections and clean them up
Old 01-26-2013, 01:41 PM   #7
jabela
If your fuel pump hasn't been replaced recently, then change it and your fuel filter. The pumps regularly fail between 150 and 200k km, or 10 years.
2002 E46 325ci // 5spd // Sport Suspension
www.modernapothecary.ca
