Old 01-01-2013, 01:22 PM   #1
Mdrie
Fitment of rims on E36 and E46
Over the summer I bought a 2004 325xi that came with winter tires on 16 inch rims. Would the rims fit on an E36 M3? (i.e. is the bolt pattern the same).
Any input is appreciated!
Mdrie is offline   Reply With Quote
Old 01-01-2013, 02:42 PM   #2
richie_s999
E36 m3 usually require 17 inch rims to clear the brakes
Old 01-02-2013, 08:54 AM   #3
Dinanstu
16" will clear the brake caliper.
Bolt pattern is the same.
Put them on the front to see if the offset affects the turning radius (rubbing) and struts.
Need an s54 MZ3 coupe...will trade...
Old 01-02-2013, 09:57 AM   #4
KIRASIR
Your Nightmare
KIRASIR's Avatar
Nope, they won't clear the brakes. There is only a couple of very specific models of aftermarket 16" rims that will fit the e36 M3 (chances that OP has either of them is pretty much zero).
Otherwise, non-M3 e46 has the same bolt pattern and offset as e36 and all the wheels are interchangeable(assuming they clear the brakes of course).
KIRASIR is online now   Reply With Quote
