Old 12-21-2012, 12:24 AM   #1
noid
noid's Avatar
Anyone know of reasonabily priced shops that can press in/out bushings?
Have my rear subframe out and completely disassembled, I only need a shop to press in and out the subframe bushings and trailing arm bushings.
Anyone know of any shops that will do it for a reasonable price?
Old 12-21-2012, 02:55 PM   #2
Was going to tell you to ask that guy in burlington offering he's garage for free, but then realized that was you, haha.
While i'm sure any shop with a press should be able to do it, I don't know any in your area. Another option, given that you are such a DIY'er is buying a cheap press.
For about $200 you can get something like this, maybe even cheaper if you look for something used. You'll need to find a few metal pieces here and there to fit the part to push them out. If you have a ball joint kit, they usually come with a few.
http://www.princessauto.com/pal/prod...Ton-Shop-Press
Old 12-21-2012, 04:27 PM   #3
noid
noid's Avatar
I really don't need a press. To push them in an industrial vise is sufficent, which I already have. I called RMP and even they burn them out. I just wanted to avoid being "that guy" burning out bushings on the street. But at $250 for RMP to do it I think ill just be doing it myself.
Old 12-21-2012, 07:02 PM   #4
_JohnnyD_
_JohnnyD_'s Avatar
Burning them out is a messy process. Its a pain in the a$$ to clean out the melted rubber from the holes for the bushings in the control arms. The sub frame bushings have a steel sleeve that you'll need to cut out once your done burning the rubber. I had mine pressed out and new bushings pressed in at Lock St. Auto in Hamilton but his price was far from reasonable.
Good luck.
“Life is a series of experiences, each one of which makes us bigger, even though sometimes it is hard to realize this...”
Henry Ford
_JohnnyD_ is offline   Reply With Quote
Old 12-22-2012, 06:43 PM   #5
DIRT_Racer
DIRT_Racer's Avatar
also, if you have a cheap ball joint press from princess auto, it can also be used for doing just what you are thinking!
See the #90 DIRT 318i @ www.facebook.com/brewstermotorsports
DIRT is for racing, Pavement is for getting there. The only way to turn left, is to turn the wheel RIGHT!!
Locked Your DIff and hate it?
Give me a shout, will buy em up cheap, DIRT tracks are the ONLY place for a welded diff!!
DIRT_Racer is offline   Reply With Quote
Old 12-22-2012, 10:52 PM   #6
kenmar
You can try Howard at his machine shop called New Dimension (ND). 101 Meyerside Dr, U#5 in Mississauga at 905-867-4234
I had him do some machining for me and asked him about pressing in ball joints and the quote was pretty cheap (sorry, don't remember the exact $ value). He said he would be able to handle pretty much anything after being in the auto machining business for close to half a century.
Old 12-23-2012, 01:09 AM   #7
noid
noid's Avatar
Burned out the subframe bushings out today.
Was still a pain to get out, sawzalling wasnt that effective (I choose not go over do it since I do not want to saw into the subframe tube).
I used my industrial vise to keep crimping the exposed end while heating the outside with a mapp torch. After a while of messing with it, it came out. The other side I decided to try something new. I took a 1 1/2 inch metal electrical pipe coupler from lowes, that fit PERFECTLY.
In the vise, on one end I used the 1 1/2 pipe, on the other I used two sockets on the tips of the subframe, which worked well. Heating the outside of the bushing tube with a mapp torch helps.
The whole process would have been easier with a helper. The marjority of my time was spent wrangling the subframe on the vise.
For the trailing arms I got a 7/16 threaded rod from lowes, five 7/16 nuts and an assortment of washers:
Excuse the blurry shot:
Old 12-23-2012, 02:22 AM   #8
KIRASIR
Your Nightmare
KIRASIR's Avatar
That press goes on sale once in a while for around 80 bucks...
