Old 12-15-2012, 12:24 AM   #1
5style
Hatters gon Hatt
5style's Avatar
e36 front suspension geometry questions
I just got coilovers and here is the scenario:
-control arms non m3
-Lcabs 95 m3 offset for castor
-spindles: 95 m3 for m3 brake upgrade
-sway bar 28mm with non m3 endlinks
-top shock mount: centered
So at my current ride height, everything is great.
I wanna install the coilovers but I want to get new top mounts, and I am afraid that if I use centered ones, the extra castor will cause my front wheels to rub the inner wheelwells when I lower it....
Do the 95 m3 top hats delete some of the extra camber??? or is it less with centered, or do I need to go 96 m3 inorder to move the wheel back to centered more??? Do the 96 m3 top mounts delete some camber too? I need the camber....and some castor would be nice....
Can someone chime in?
Old 12-15-2012, 12:44 AM   #2
5style
Hatters gon Hatt
5style's Avatar
damn it im so confused
Old 12-16-2012, 01:45 PM   #3
5style
Hatters gon Hatt
5style's Avatar
problem solved, castor and camber adjustable plates ordered
Old 02-03-2013, 10:29 PM   #4
L1V3N 1T
L1V3N 1T's Avatar
did you get ground controls camber/caster uppr mounts?
L1V3N 1T is online now   Reply With Quote
