Old 11-21-2012, 06:01 PM   #1
Pop-o-matic
WHat's the best code reader
I owned my 328is for 10 years now and I'm tired of "guessing" everything.
So, I want the best tool to read the basic fault codes.
I know I'll need the 20pin adapter for sure but is there consensus on what is
the tested and true reader that most ppl use?
Pop-o-matic is offline   Reply With Quote
Old 11-21-2012, 07:03 PM   #2
sgolas_e46
sgolas_e46's Avatar
I was thinking of getting the smart phone wifi obd2 reader . Connects wirelessly to any smartphone and runs on a app that reads codes , re sets them and a bunch of other options its actually very neat, you can find them online from 40-80$ just gona research it a bit before I buy
sgolas_e46 is offline   Reply With Quote
Old 11-22-2012, 11:52 AM   #3
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I have the Peake scanner, its simple and works great.
Old 11-22-2012, 11:58 AM   #4
ScotcH
The base OBD2 readers only read the common codes. Many can't read the full BMW codes. If you can afford to spend the time to learn how to setup and use it, the BMW GT1 software for a PC is best (or the newer variants). Get the cable and 20pin adapter online for like $40, and "find" the software elsewhere.
If you just want to scan and reset basic codes, the Peake reader is really the way to go.
Old 11-26-2012, 06:32 PM   #5
Pop-o-matic
Thanks Arek I like to tinker so I'll give a try to that GT1 software.
Old 11-26-2012, 10:58 PM   #6
ScotcH
Didn't see you're local! I can help with setup of the software if you run into issues.
Old 11-27-2012, 01:06 AM   #7
Pop-o-matic
Great! Thanks. It's funny, it easier to reach you through Maxbimmer than
through 8 Legs...
Old 11-27-2012, 09:22 AM   #8
ScotcH
through 8 Legs...
Lol ... did you email, or what? Maybe a technical glitch ... I'm usually pretty good at answering asap!
