Old 11-19-2012, 05:29 PM   #1
jabela
car just died
ok my 2002 325 just died. started hesitating at part throttle, then totally stalled and wouldn't restart. it did seen to be ok at more that 50% throttle before it died.
engine code reads lean on the exhaust.
my guess is bad fuel pump. what do you guys think?
I'm just sitting here waiting for CAA to you're my car to cross ave auto. anyone recommend any other shops closer to Mississauga near the qew?
thanks
jon
2002 E46 325ci // 5spd // Sport Suspension
www.modernapothecary.ca
Old 11-19-2012, 05:42 PM   #2
//my guess would be fuel pump too, perhaps a maf if it will only idle at high rpm?
www.enthusiastauto.caContact if you are looking for a car
His--2000 BMW ///M5 .:Jet Black on Black:. Individual - Style 65 Wheels; 9.5" Square Set up;275 Tires;10mm/3mm Spacers; Black Kidneys;Muffler Delete; 3.5" Dual Tips; Beast Power Sway Brackets; "Dinan" Ducts; E60 SSK; BC Coils
Hers--2000 BMW ///M5 .:Avus Blue on Grey/Black:. '01 Exterior Upgrades; E60 SSK
bmwm5lover is online now   Reply With Quote
Old 11-19-2012, 07:00 PM   #3
jabela
I can't hear the fuel pump either, and the car won't restart, so probably not the maf. I just wish it happened near my home so I could replace the pump myself. seems to be a pretty common failure.
Old 11-19-2012, 07:19 PM   #4
BmW1819
my alternator just died on me bad day for us lol
BmW1819 is online now   Reply With Quote
Old 11-19-2012, 07:30 PM   #5
cormier
cormier's Avatar
Oh jeez you guys bad luck eh
You already get towed out of there?
Old 11-19-2012, 07:37 PM   #6
BmW1819
looking for a new car now lol
Old 11-19-2012, 07:41 PM   #7
SamE30e
SamE30e's Avatar
Check the intake boot, could be split. Unmetered air causing a lean condition. E46's are known for them.
91 318is - M50NV (gone)
85 - 325
02 325i Sedan
Old 11-19-2012, 08:53 PM   #8
Car would still run if that was the case.
Goodluck finding a fix, shouldnt be too hard.
Dare I squeeze
Old 11-19-2012, 08:58 PM   #9
jabela
Tow truck driver said he had another E46 with coolant system failure earlier today.
Yea, I don't think it was the intake. I replaced it a few years ago, plus car would start if that was the case as mentioned above.
Anyhow, I hope it's just the fuel pump. It's the only thing that makes sense. Maybe the throttle could have failed and stayed closed?
Old 11-19-2012, 09:05 PM   #10
cormier
cormier's Avatar
^^ Icv would have supplied air and the motor would run
Crank no start, fuel or spark
Old 11-19-2012, 09:21 PM   #11
Blackedout95
Too many common issue could have caused this, won't know for sure until you get it looked at. GL
E46
Blackedout95 is online now   Reply With Quote
Old 11-19-2012, 10:26 PM   #12
cormier
cormier's Avatar
... Or just look yourself pull a fuel supply line crank it and see if you get wet!
Old 11-19-2012, 10:35 PM   #13
jabela
lol, in my garage maybe. Not in the dark in middle of the road. I died while I was waiting at a red light.
I felt it hesitating around 1000-2000 rpm while moving, so at the light, I tested by revving a bit, then it just died.
We'll see tomorrow.
Old 11-19-2012, 10:41 PM   #14
Blackedout95
I once had this happen in my e36, turned out it was the maf but like we've said could be anything from fuel delivery to a vaccum leak in the boot to tps to the price of tea in china.
E46
Old 11-20-2012, 01:09 AM   #15
jabela
lol.. true, you never know.
So you couldn't restart your car with the MAF problem?
It happened so quickly that it's hard to believe it could be a vacuum problem. 30 seconds after the first hesitation it died completely. Certainly felt like fuel starvation.
