Old 11-15-2012, 08:11 PM   #1
grant_jr
grant_jr's Avatar
Unhappy Speakers Issue
Greetings,
So I recently bought an e30 from a member on this board and I have and issue with my speakers not working.
So the problem started when i went to jump the car after the battery died, I left light nob in the middle -___-"
i connected the cables and started my dads van and got nothing but the cables burning so i called CAA and the dude that came told me that who ever installed the audio system switched the lables on the battery, negative labeled positive and so forth.
He said if i had tried to jump this on a newer vehicle i might have fried the whole car. luckily it just affected my speakers.
so would anyone have an idea where i should start or a shop that could take a look?
cheers
the old new baby
grant_jr is offline   Reply With Quote
Old 11-15-2012, 09:04 PM   #2
TSI
Reverse...
I'm not entirely sure how one switches labels on a battery...
If you smelled cables burning, it might just be that. Sounds like you'll have to run through the whole wiring system for audio. That being said, are you sure it is the speakers causing the problem? Do you have another headunit you can swap in, or maybe even plug the speakers into an amp to test them?
My strategy would be that: test each individual component until you find the broken one, and replace. I hope you have a multimeter
Where are you located? I might have some time in December to help you out.
TSI is online now   Reply With Quote
Old 11-15-2012, 09:43 PM   #3
grant_jr
grant_jr's Avatar
I live in woodbridge(weston and major mak, i'll be on break from school in December so if i don't get it fixed by then we could defiantly meet up and get it sorted out.
I do have a multimeter so i'll see what i can find.
Old 11-15-2012, 09:59 PM   #4
cormier
cormier's Avatar
Good advice on the first post-- and no I don't quite understand that battery issue either...
I might be able to swing by this weekend and give you a hand
Old 11-15-2012, 10:00 PM   #5
grant_jr
grant_jr's Avatar
im going to go run out and take a picture so you can understand me fully.
Old 11-15-2012, 10:18 PM   #6
grant_jr
grant_jr's Avatar
This is what i was talking about the wires were switched. Looking back I should have caught it because the negative is grounded to the frame. -__-"
Old 11-15-2012, 10:31 PM   #7
grant_jr
grant_jr's Avatar
My deck works perfectly fine. Powers off and on and all that jazz so I'm guessing the amp or speakers are blown.
Cormier, if you have any time this weekend pm me your digits and we'll link up. Cheers.
