Old 11-04-2012, 08:57 PM   #1
BlazeStar
Winter tires for my BMW 535i 2012
Hi guys,
New poster here.
New BMW owner too!
So I was searching around in the forum and didn't quite find what I was looking for so I just thought I'd start a thread.
Just bought this summer a 2012 535i, with the M Sport Package.
Now "Winter is coming" and I'm starting to look for tires.
1) Do you recommend I keep the M Sport Package mags or use rims or another set of mags, for winter?
2) Do you have any tires to recommend to me? I'm looking for cost efficient tires.
Thanks guys!
BlazeStar is offline   Reply With Quote
Old 11-04-2012, 11:50 PM   #2
ChrisTO
∞ Gear Member
always better to get a second set of rims...works out cheaper and better for the tires long run with the constant swapping on and off rims twice a year. and the time you spend waiting for the tires to be remounted and balanced each time.
tire rack sometimes has some great deals when they try to clear inventory.
rims - i'm partial to OEM even for winters. try kijiji? Not sure if the offset of the rims are different from the e60 generation. many used sets of rims from that MY. if they work get those. knock offs sometimes vary in quality and a cracked rim in the winter is far more troublesome than in summer. and we know how pot hole ridden the city becomes in the winter.
ChrisTO is offline   Reply With Quote
Old 11-05-2012, 01:08 AM   #3
BlazeStar
Thanks Chris,
I did think it'd be better to go with rims for winter tires too.
But same size as OEM ?
My tires are :
Front: 245/40R19
Rear: 275/35R19
So what size of rims should I be looking for... 19" ?
Old 11-09-2012, 10:35 AM   #4
BlazeStar
Guys, I see there's a lot of discussion about this... what do you think about this:
Can I go for NON runflat tires for winter?
BMW dealership says it will affect the handling of my car.
Is it true? Is it that bad?
Because the prices I get for runflat tires are more than twice the price of their regular equivalent...
Let me know
Old 11-26-2012, 11:47 AM   #5
dtthiaga
Don't believe a word the dealer tells you.
.....their main goal is to sell you a $3500 Winter tire package.
Sure, you are going to loose performance with Winter tires (don't get true performance snows). It's winter. Think Safety and Black Ice.
With these run flat cars, I still put regular snows on.
Buy a canadiantire patch kit, can of tire inflate, and a portable pump and you are good.
I've had to use it once, and never missed not having a spare tire (nor run flats).
..... didn't even remove the tire.
TireRack has a Firestone Winterforce 17" on Alloys for $992/set
I'd run a 225/55/17 for snows (all four - thinner is better)
You culd run 245/50/17 on the bigger 5 Series.
You could also run 225/50/18 tires.
I usually don't install the TPMS either for the winter setup ..........Your call.
dtthiaga is online now   Reply With Quote
Old 11-27-2012, 12:03 PM   #6
KCX_335xi
Whatever you do, DO NOT get a new set from a dealer.
Try Kijiji for a used BWM OEM set...
KCX_335xi is offline   Reply With Quote
Old 11-28-2012, 10:31 PM   #7
ChrisTO
∞ Gear Member
^ that's what i did...bought a used set that way and used the tires for 2 more seasons before selling them. there's always people looking to put tires on with just a bit more tread to pass safety when they do a lease return.
and yes go for smaller size tire for winters. the door jamb and manual will show the proper M+S sized tire.
and as others have stated avoid the dealer purchase. really you don't need star rated tires.
Old 11-29-2012, 04:06 PM   #8
bmmernut
Wrencher of BMW Ferrari
it is good to run a narrower tire for winter that has the same overall "turns per mile" as the stock tire. Tire rack is a great resource with their online fitment or by phone. I have been really happy running Pirelli Carving or Winter210.
bmmernut is offline   Reply With Quote
Old 12-03-2012, 06:36 PM   #9
BlazeStar
Thanks all for your answers... it was great help
Old 12-03-2012, 06:38 PM   #10
BlazeStar
I did not install the TPMS on the winter tires...
now every single time I start the car, it tells me to drive slow and that the TPMS failed...
anything to do with that or I just ignore it?
