Old 10-21-2012, 10:31 PM   #1
subarooo
subarooo's Avatar
POLICE safety inspection?
So i just got pulled over for being to "low". Ended up getting a road side inspection. He got me with a bunch of things but only ticketed me with no horn (easy fix). But hes making me go for a safety inspection on wednesday. He said im aloud to fix stuff before i go in, Only one issue. Im on bags, Whats the law about bags? Considering i made my own brackets and welded them on i think im screwed. Im pretty sure i can fix everything else, the horn, put my stock wheels on. But im not sure about the laws on bags, Im running a manual system, so if they over inflate they'll blow the sleeve up. So i have to tell them what im running. I also cant put the stock stuff back in. I had to cut the trailing arm apart to make it work.
Any help?
Car in question
subarooo is offline   Reply With Quote
Old 10-22-2012, 02:12 AM   #2
1bmw1
Sorry to hear this happened to you. I guess the cop wasn't a car enthusiast lol.
Joking aside, They can't force you to put your car back on the road. If you can't get the things fixed on your car before Wednesday, i think you're entitled to let them know that you are not going to bring the car in because you don't have enough time to fix the issues therefore tell them you're prepared to have the car taken off the road until you can fix it. After that, i think you'll be ok to get it saftied and e-tested elsewhere and get it back on the road as if you would on your own.
Old 10-22-2012, 10:26 AM   #3
You can voluntarily decline the inspection (car's status will be changed to unfit). Then all you need is a safety to get it back on the road. I wouldn't recommend doing this often, they will catch on.
Old 10-22-2012, 10:51 AM   #4
subarooo
subarooo's Avatar
Will they inspect it after i get the safety? I think a hot safety is my only choice at this point.
Old 10-22-2012, 03:30 PM   #5
IChopCars
aka ROOFLESS
why dont you set the bags to a reasonable height and then disconnect the switchs. Just tell them that its an air suspension instead of your standard macpherson strut. Lots of vehicles come with airbag susension from the factory.
If not, like you said above. A non legit safety is the way to go.
IChopCars is offline   Reply With Quote
Old 10-22-2012, 04:16 PM   #6
dylanneon
yeah, technically adjustable air suspension is against the hta, but if you disconnect/hide the switches you may be able to get away with it. at this point it would come down to how much the tech knows about bmw and how professional the install looks.
dylanneon is offline   Reply With Quote
Old 10-22-2012, 06:10 PM   #7
subarooo
subarooo's Avatar
I can't remove the switches. All the air will drain out because im on a manual setup. And I'm pretty sure the guy who started "erace" is doing my inspection. I'm getting pretty nervous that it won't pass. Do I have to get a special safety after its deemed as unsafe?
Old 10-23-2012, 08:57 AM   #8
SamE30e
SamE30e's Avatar
It's not hard to pass a safety. If it doesn't pass a safety, then it's unsafe.
Getting a "fake safety" is stupid. Just make your car legal and that's that. If you bullshit your way to a fake safety then you're putting the technicians license at risk. Mind you, if they're a good tech, they won't pass it.
Read up on the safety legislation on air ride if that's all you're concerned about.
85 325 - Turbo M52B28.
Old 10-23-2012, 09:52 AM   #9
subarooo
subarooo's Avatar
The car is safe, the only thing I'm nervous about are the bags. Nothing in the HTA says anything about air assiste suspension or ride hight.
Old 10-23-2012, 10:36 AM   #10
Talk to some VW guys. There's lots of them rolling around on bags. I'm sure some of them have had to do a safety at some point in time.
Old 10-23-2012, 11:30 AM   #11
SamE30e
SamE30e's Avatar
Then you have nothing to worry about. Just make sure everything is in order. If they say it fails because of the air ride. Ask to see the regulations against the infraction.
Your car doesn't even technically need lights to pass safety.
Old 10-23-2012, 11:34 AM   #12
lots of cars come with stock airbags, including BMW and some of them are adjustable (Rangr Rover and older Subaru's) and they are legal!
Old 10-23-2012, 12:54 PM   #13
Blades
Your opinion is to long
Blades's Avatar
My fathers old lincoln Mark 5 came STOCK on bags .. smoothest ride ever. I don't see how they can make one car legal on bags and another not. It must be only the height issue and that it is adjustable while driving (safety concern) if there was a way to hide the switches you should be ok.
-=[ BL/\DES ]=-
Old 10-23-2012, 02:04 PM   #14
SamE30e
SamE30e's Avatar
Because you're modifying the factory suspension design. He said he made his own. Not saying his is shit, but some people have no idea what they're doing, making it unsafe. If I was on the highway and someone hit me as a result of something like this, I would lose it.
Old 10-23-2012, 09:29 PM   #15
MANDD
Autobahn East
Check out this link From York Regional Police.
www.yrp.ca/erase/side.htm
