Old 10-14-2012, 12:49 AM   #1
civic_eater
civic_eater's Avatar
E38 v8 low rpm hesitation and rough idle
Changed my coils and plugs and no difference below 2000-1500rpm it seems to sputter after it is warmed up and has a rough idle pls help
civic_eater is offline   Reply With Quote
Old 10-14-2012, 11:22 AM   #2
Nick_V
Nick_V's Avatar
My first guess would be intake manifold gaskets. Try spraying some carb cleaner around them with the car running and see if the idle changes. Also check your intake boot and all vacuum lines for cracks/leaks.
Old 10-15-2012, 10:57 AM   #3
Pull Codes!
When I was having similar issues, it happened to be my CPS (Cam Position Sensor)
Follow me on Twitter @SEVEN40iL
740-iLL is online now   Reply With Quote
Old 10-15-2012, 10:09 PM   #4
civic_eater
Thanks guys
Old 10-16-2012, 09:50 AM   #5
So....
What was it?
Old 10-22-2012, 03:45 PM   #6
civic_eater
Duno yet will post
Old 10-22-2012, 04:59 PM   #7
Mr.535
Mr.535's Avatar
Ive seen excessive cps gap and bad cps do that before.
2001 Laguna M3
1989 535i -11:1 N/A M30 complete,BW S375 build begins
Mr.535 is offline   Reply With Quote
Old 11-01-2012, 10:38 PM   #8
civic_eater
I read the codes and it is saying that it has a random misfire in cylinders 1-4
Old 11-01-2012, 10:39 PM   #9
civic_eater
Could that be caused by a bad cps?
Old 11-02-2012, 09:37 AM   #10
Bad CPS would come up as a bad CPS.
Random misfire could be caused from a few different things.
What were the codes that you got?
