10-11-2012, 09:41 PM
#1
Car: Kia forte5 sx slow
Issue with my e30
Hi!
I bought a e30 in june. It a 325i 1989. When i start my engine, he cranking like 8-10 sec before the engine run. What the problem?
And my fuel gauge don't work, so he flicking?
Sorry my english, i'm french from montreal!
10-11-2012, 11:39 PM
#2
Car: 325IS 87-325IC 89-IC
could be a number of things. check the fuel pressure regulator; check pump for adequate fuel pressure.
the fuel gauge problem may be a loose nut on the back of the gauge. tighten it down.
10-12-2012, 01:16 AM
#3
You think is my fuel pump is the problem?
The nut on the back gauge is tight!
10-12-2012, 07:59 AM
#4
then it is probably a faulty gauge - which you'll need to replace. OR...If you're fuel level switch in the tank is bad it may cause you to get a false reading on the gauge. And if that filter in the tank is clogged it may delay fuel delivery to the injectors.
Try changing your fuel filter first. cheapest and easiest fix first.
10-12-2012, 10:32 AM
#5
Filter is new since last week, same problem.. for the gauge, i have changed, the second gauge flick too
10-12-2012, 02:28 PM
#6
you might have a problem with the SI board inside the cluster. batteries usually go in those.
but you still haven't checked the sending unit in the gas tank have you?
10-12-2012, 02:45 PM
#7
Car: E46 Coupe
Sending unit in fuel tank for guage problem. Change the fuel pump and regulator for startup issues.
German Mechanics
2530 Speers Rd #5
Oakville, ON Canada
(905) 286-4362
Mon-Fri 9am - 5pm
www.GermanMechanics.ca
10-12-2012, 09:22 PM
#8
Sending unit come with the pomp if I buy a brand new?
10-13-2012, 07:44 AM
#9
for an 89-325 -should come complete.
10-14-2012, 11:19 AM
#10
Car: Ugly M50 swapped E30
I had the exact same problem with my old e30 sedan. It was the fuel pump being on its way out.
Originally Posted by 411
10-29-2012, 08:45 PM
#11
Car: 1987 320i
Hey my 87 320i was doing the same thing...I fixed it by polishing up the grounding point next to the battery...it didn't look corroded and was very secure...but hitting it with some emery cloth made a huge difference in how the car starts....try it it's free
11-28-2012, 02:22 PM
#12
So!
Have changing the sending unit.. the gauge flick again!
Startup issues:
Change the fuel pump, polishing the ground. The problem is not solved. I think change the fuel regulator
11-28-2012, 02:31 PM
#13
Car: many
used fuel pumps are cheap, and very easy to replace.
as for the flicking gauge, it's all part of the beauty of E30 ownership.
I fix it with a heavyhanded whack to the dashboard.
11-28-2012, 04:52 PM
#14
Reverse...
Car: '88 325i
I find this works for most things in life...
11-28-2012, 05:05 PM
#15
Car: 84 S52 e30/330ix e46
You'll learn the sweet spot and amount of force to inflict....repeatedly...
top of console works well for me
