Old 10-04-2012, 01:47 PM   #1
NOTORIOUS VR
NOTORIOUS VR's Avatar
Anyone have a single VANOS seal kit in stock locally?
Kind running on a tight schedule and would prefer to be able to pick it up off of someone privately or a vendor here.
Thanks!
E36 · VEMS · TUNING
Google Talk: NOTORIOUS VR
Old 10-04-2012, 03:04 PM   #2
marek
There is a new double vanos kit for sale on kijiji for $60. Not sure if the seals are the same size or not?
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ417594068
marek is offline   Reply With Quote
Old 10-04-2012, 03:33 PM   #3
NOTORIOUS VR
^^^ Amazing, thanks Mark.. I will find out if I can use it, cheers!
EDIT: I got an answer back from Besian, I can't use that kit on my single VANOS
E36 · VEMS · TUNING
Old 10-04-2012, 07:57 PM   #4
SiR
Vtec just kicked in
take your old seal to any decent o ring place(there are quite a few in the gta) and match it up with a viton o ring(which are common in industry)...
Id wager a lot you can find what you need....though not sure what you would do with the teflon seal part... you could also try the same idea.
Oring shouldnt be a problem...teflon seal may be.
some measurements the single vanos o ring size is M2.62X77.5 which is a european din size. (I just measured and compared my measurements to chart)
though better to compare with old unit.
the teflon seal ID is the 82.xx of the oring od.
these guys have a lot. Ive been to them for other car orings and matched things up
and they also carry a wide range of teflon seals.
http://www.ablesealanddesign.ca/
If you dont do this ...Im likely to make the trip to see for myself.
-||Old Crayons||-
Old 10-04-2012, 11:52 PM   #5
NOTORIOUS VR
I'm gonna leave it for now.. My VANOS was quiet and there is virtually no play in the unit as it is, I guess it was just kinda one of the "while I've got this apart" thing to do.
Thanks for the help guys.
E36 · VEMS · TUNING
Old 10-05-2012, 12:16 AM   #6
pawelgawel
Why hasn't anyone in CAN come up with own seals solution??
SiR if you have the dimensions, why don't you look into the oring and teflon seal availability from a source here in TO?
pawelgawel is offline   Reply With Quote
Old 10-05-2012, 12:57 AM   #7
SiR
Vtec just kicked in
because $60 for everything besian offers is fine to most and they dont want to waste their time running around the city.
I may
-||Old Crayons||-
Old 10-05-2012, 08:34 AM   #8
NOTORIOUS VR
This, and I don't want to bother as I know the Besian Systems kit works.
And it's only $30 + shipping (not $60)
E36 · VEMS · TUNING
Old 10-05-2012, 03:51 PM   #9
SiR
Vtec just kicked in
ya.. +$30 for the anti rattle + more if you get the extras.
-||Old Crayons||-
Old 10-05-2012, 04:08 PM   #10
NOTORIOUS VR
yeah... what I did forget to get that I actually need now was the damn VANOS unit/cylinder head seal... Marranello not in stock, have to wait till Tues.. always the small things that get you.
E36 · VEMS · TUNING
