Old 09-26-2012, 09:26 PM   #1
Seyar
Seyar's Avatar
Has anyone used plastidip
I've seen emblems,grills and roofs, but today for the first time I saw a whole car.
Has anyone on here sprayed a entire car?
INTERLAGOS E36
Seyar is offline   Reply With Quote
Old 09-26-2012, 10:00 PM   #2
L1V3N 1T
L1V3N 1T's Avatar
There is a dealer in my city that has his Audi plasti coated blue looks killer and if your bored of the colour just peal it off!
L1V3N 1T is online now   Reply With Quote
Old 09-26-2012, 11:47 PM   #3
Blackedout95
I kind of get doing some emblems if you want to be able to peel it off after but otherwise...ugh. No reason to cover a clean car it that crap, just another step towards stupidity.
E46
Blackedout95 is online now   Reply With Quote
Old 09-27-2012, 12:18 AM   #4
Eurostyle
Eurostyle's Avatar
I did....
Eurostyle is offline   Reply With Quote
Old 09-27-2012, 12:20 AM   #5
98bimmer
Hows your paint under the plasti dip fil?
98bimmer is offline   Reply With Quote
Old 09-27-2012, 12:26 AM   #6
Seyar
Seyar's Avatar
how hard is it to keep clean and how do you wash it Phil?
INTERLAGOS E36
Old 09-27-2012, 01:11 AM   #7
Eurostyle
Eurostyle's Avatar
Not too sure what you mean...Painted right on top, no special prep. Still can be taken off at anytime without damage.
Old 09-27-2012, 01:15 AM   #8
Eurostyle
Eurostyle's Avatar
Better then any "normal" paint job, but like any black it has to cleaned on regular basis. I use a 2500psi pressure washer on it with no issues at all, as long as you dont put it right next to the surface! Soap or degreaser works well...
Old 09-27-2012, 09:18 AM   #9
SiR
Vtec just kicked in
there are diy threads out there and on youtube.
better to use an airgun to spray it if you can
-||Old Crayons||-
Old 09-27-2012, 10:02 AM   #10
GeMc
GeMc's Avatar
I've used it on my old wheels and had the tires unmounted/remounted twice without it coming off (new tire machines are awesome). Strong as hell, but make sure you use a lot of it on application as it needs to be thick for proper removal. If it's too thin, you'll be forever picking it with your fingernails. As an example, I used 1-spray can per wheel. Get it at your local Home Hardware store.
German Mechanics
2530 Speers Rd #5
Oakville, ON Canada
(905) 286-4362
Mon-Fri 9am - 5pm
www.GermanMechanics.ca
GeMc is offline   Reply With Quote
Old 09-27-2012, 12:59 PM   #11
328IScreamer
328IScreamer's Avatar
I never thought about this as a rim coat application......this is a great idea for flat black rims
How much does 1 spray can go for?
Old 09-27-2012, 01:05 PM   #12
98bimmer
Sorry i meant was there somethig wrong with your paint thats why you dipped it? Or you just wanted to change it up?
Old 09-27-2012, 02:28 PM   #13
Dysantic
Captain Chaos
Dysantic's Avatar
+1. I never thought to do this. My winter rims are looking pretty rough and rather get them refinished or something this could be the perfect idea.
Old 09-27-2012, 02:41 PM   #14
NOTORIOUS VR
NOTORIOUS VR's Avatar
it's around $19 I think.. used to be less around $14-15
E36 · VEMS · TUNING
Google Talk: NOTORIOUS VR
Old 09-27-2012, 03:34 PM   #15
Blades
Your opinion is to long
Blades's Avatar
I did....
How many cans did it take you?
-=[ BL/\DES ]=-
Blades is online now   Reply With Quote
