Old 09-05-2012, 08:50 AM   #16
And just to show that there is an improvement with a tune, this is a quote from bf.c with dyno before and after an m50 manifold.
Notice the drop in torque you don't see above.
Originally Posted by sfdrifts View Post
Red curve is with the m50, I barely notice the drop in the 3k range when driving and she really opens up after 4k now, very happy with the m50 swap.
Dare I squeeze
Old 09-05-2012, 09:32 AM   #17
BigD
the misanthropist
BigD's Avatar
My point is that tuning is not necessary to use the M50 manifold. If you want to mess with the timing, power can be gained with any manifold, since they build in a safety margin from the factory (and as such, it's not an especially great idea unless it's a track car). But the manifold alone does not require any kind of special tuning just for its own sake. A better manifold simply lets you flow more air. The MAF and IAT readings will inform the DME of this and it will adjust the fuel in step.
Old 09-05-2012, 10:45 AM   #18
Nolimit77
This was the only point I was trying to make in my OP. Perhaps we can get more people in here to share their experience with this swap.
Nolimit77 is online now   Reply With Quote
Old 09-05-2012, 10:53 AM   #19
Fair enough, I was just responding your statement that it was a waste of money.
Pretty sure it is well understood that a tune isn't required and that there are top end gains and some low end torque loss without a tune, but a tune can help get some of the low end torque that is lost back, so it isn't completely worthless, just another mod.
Dare I squeeze
Old 09-05-2012, 11:59 AM   #20
SiR
Vtec just kicked in
you dont need a tune with the m50.
though as pointed out it can help recover some of the torque drop
-||Old Crayons||-
Old 09-05-2012, 11:59 AM   #21
Eau_Rouge
For those who've done it, how does this swap affect fuel mileage?
Eau_Rouge is offline   Reply With Quote
Old 09-05-2012, 12:06 PM   #22
Nolimit77
I wish I could comment, but my car is for the track only. I have read some people say that MPG went up but I am not sure if there is any truth to it.
Old 09-05-2012, 01:44 PM   #23
SiR
Vtec just kicked in
you likely wont notice any change.
Driving habits, conditions and time of yr will be bigger factors in any mpg changes.
Its not like I hopped in and instantly banged off 100 more km per tank.
Even running shell vs other stations gas can effect mpg.
Overall mileage will stay the same between the two manifolds.
-||Old Crayons||-
Old 09-05-2012, 04:06 PM   #24
Eau_Rouge
I wasn't expecting mileage gains just didn't want to hear that mileage dropped significantly. If it stays approximately the same, then I'm happy.
Old 09-05-2012, 04:16 PM   #25
1BADBMR
I've never considered a tune when I did my M50 manifold mod on my S52.
After the installation, I noticed a loss of torque down low, but I gained it all back on the top end! Great bang for buck imo, even w/o a tune
Alvin
"Dare I squeeze three at yo cherry M3" - Hypnotize (Notorious B.I.G.)
_____________________________________________
98 M3 Sedan
06 Yamaha R6 (SOLD)
04 Honda Civic (Beater)
93 318i (SOLD)
1BADBMR is offline   Reply With Quote
Old 09-05-2012, 05:15 PM   #26
If your driving habits stay the same you won't notice any difference.
Of course if you start ringing the motor out more often to enjoy the top end power you will decrease your mileage, but that's pretty much a given.
Dare I squeeze
Old 09-05-2012, 11:27 PM   #27
doogee
Stance is Gay.
doogee's Avatar
Back when I just bought my 328is, it dynoed 198rwhp on a Dynojet with the only mod being an M50 Manifold.
But cams and a tune took it to 220rwhp.
Dakar M3 Track Build Thread
doogee is online now   Reply With Quote
Old 09-06-2012, 01:07 AM   #28
KIRASIR
Your Nightmare
KIRASIR's Avatar
I just did this swap two weeks ago.
My butt dyno didn't feel much difference in the low end. The top end seems to rev quicker with much smoother acceleration after 4k.
The mileage appears to be unchanged.
KIRASIR is online now   Reply With Quote
Old 09-06-2012, 11:43 AM   #29
Eau_Rouge
If this is the case, assuming a 15% driveline loss of power, then with cams and a tune, the engine puts out roughly 260hp at the crank.
Next question is why do some bother with an S52 swap, why not just go this route?
Are cams and a tune expensive?
Old 09-06-2012, 12:37 PM   #30
sb_600
sb_600's Avatar
S52 cams are about $300-400 used, and a tune is in the $350 range as well.
Shawn
