Old 07-23-2012, 04:59 AM   #1
Klipzs
Need help installing aftermarket car deck on my e39 plz
Just bought an alpine 133bt from crutchfield with the wire harness adapter.
I removed the stock head unit and disconnected the wires.
Soldered/crimped the wire harness to the car deck adapter.
Turned it on but no sound except staticy noises ( The noise you hear when you are flickering tv channels)
Did I miss a step?
The speakers are still stock if that helps.
Klipzs is offline   Reply With Quote
Old 07-24-2012, 11:53 AM   #2
Lang75
220 Kph, E39 on Autobahn
Did you connect the relay wire for the factory amplifier?
Lang75 is offline   Reply With Quote
Old 07-24-2012, 02:17 PM   #3
Klipzs
No I did not. Where do I find this wire and how do I install it?
Old 07-24-2012, 03:37 PM   #4
Lang75
Usually this is a blue wire from the deck, if you used an adaptor kit is should have provided this connection. Usually it is noted for amps or cd changes.
