Old 12-10-2012, 03:42 AM   #1
Hal900x
CSB Preload?
I had been hearing a worsening clatter from directly below my handbrake/center console area while under torque. Sure enough, the CSB bracket was cracked and the crack had run into the actual assembly a bit too.
After replacing it and the Guibo, the same issue except the sound was now higher pitched and different in tone, but similar symptoms. The same cadence, if you will, and mostly when under torque. For whatever reason it has never occurred in reverse gear. We scratched our heads a bit and decided I had bad U-Joints that were either responsible for the sound themselves (at least in part) and/or immediately damaging the new CSB and thus the repeat symptom.
Tonight my buddy said he had the answer, which is that we failed to preload the CSB and it had shredded itself. We simple centered the bolts in the slots and tightened them down, when we should have pushed it forward and then tightened. I would like some input before I order another one and go through the whole mess again. Do you think a failure to preload would cause immediate major damage to the CSB? What kind of damage would you expect? He felt that not preloading would shred the rubber, but the old CSB was cracked mainly in the bracket and a bit into the assembly itself.
Thanks a lot for the feedback.
Hal900x is offline   Reply With Quote
Old 12-11-2012, 05:29 AM   #2
http://bit.ly/SSHYwT
Old 12-11-2012, 01:43 PM   #3
Hal900x
Originally Posted by MaxBell View Post
The purpose of this thread is diagnosis feedback, not installation instruction. Any results of that Google search pertaining to repeated damage/failure of a CSB after installation, I have already viewed and do not find an exact match to my situation. To boil it all the way down, I am trying to make an informed decision whether to try again, buying another new CSB under the assumption that our mistake was the only issue, or if there is more systemic problems requiring a driveshaft shop.
Old 12-11-2012, 02:09 PM   #4
frankie591
if your u-joints are worn and notchy that could cause your guibo and csb to wear out faster than normal
Old 12-11-2012, 08:37 PM   #5
Nick_V
Nick_V's Avatar
I don't. Purely anecdotal, but I remember reading a thread pertaining to this on R3V (I think in the 24v swap section) where lots of people said they hadn't preloaded theirs and their cars were fine. I'm not saying it doesn't matter if you do or don't, but I can't see it causing, as you said, immediate major damage. I think you've got something else going on.
Old 12-11-2012, 10:03 PM   #6
SamE30e
SamE30e's Avatar
Pre-load 10mm forward IIRC.
It will cause pre-mature failure, not immediate. Unless you just do something stupid like unbolt it.
85 325 - Turbo M52B28.
