Old 06-19-2012, 12:18 PM   #1
Hurricane240
Hurricane240's Avatar
Head Gasket Tools
Anyone rent out the tools for this job?
Anyone know where to get the required socket for a good price?
I'm not too worried about the cam lock tool.
Dustin
Hurricane240 is offline   Reply With Quote
Old 06-19-2012, 12:54 PM   #2
InfiniteDice
12 Years with the E30
InfiniteDice's Avatar
Don't forget the correct tap to clean the threads in the block.
Old 06-19-2012, 01:09 PM   #3
Hurricane240
I have a full thread cleaning kit so I should be good there unless the head bolts use an odd metric size? You wouldn't happen to know it off hand so I could check would you?
Old 06-19-2012, 02:16 PM   #4
ScotcH
wut? It's m10x1.5, but you really shouldn't have to clean them with a tool ... vac and air.
Old 06-20-2012, 09:09 AM   #5
Lang75
220 Kph, E39 on Autobahn
If you are looking to clean the threads you should use a proper thread chaser and not a tap, as it can distort the threads making them loose and giving you an improper fit.
Lang75 is offline   Reply With Quote
