06-14-2012, 09:47 AM
#1
Car: 2001 325i
Rubbing of tires
Hi I purchased a BMW 325i 2001, have an issue with rubbing on my rear passenger side. The car is lowered. My current tire configuration is
Front: 225/40/R18
Rear: 255/35/R18
Without changing shocks, or rolling fenders I am thinking of going with this configuration of tires:
Front: 225/40/R18
Rear: 235/35/R18
any comments, suggestions?
Thanks,
Cheers
06-14-2012, 09:59 AM
#2
Car: 98' E39 BMW 540i
I would just by a 10mm spacer.. but then again depends on how bad the rub is...
06-15-2012, 07:03 AM
#3
Car: E36 m3
You didn't mention the wheels...
What are the wheel diam's and offsets?
06-15-2012, 09:04 AM
#4
Car: e36 m3
06-15-2012, 09:20 AM
#5
Car: MK6 GTi
Spacers will make the rubbing MUCH worse. Do not do this!
Just get the thinner tires, you should be fine.
06-15-2012, 09:28 AM
#6
Your opinion is to long
Car: 330XI
what? LOL
-=[ BL/\DES ]=-
06-15-2012, 09:29 AM
#7
Car: 330XI
Front: 225/40/R18
Rear: 255/35/R18
Front: 225/40/R18
Rear: 235/35/R18
Thanks,
Cheers
That would be your best bet. I would try to fit anything over 245 on a E46 .. 235 would probably be best.
-=[ BL/\DES ]=-
06-15-2012, 04:48 PM
#8
Car: 325Ci
+1 I have the same issue... Rubbing on the rear right side
I might get them rolled sometime soon as that is my only option since i have 235's with 10mm spacers in the back
SANI
@IAMFNAMAZIN
06-18-2012, 02:49 PM
#9
BMW
Car: 2002 BMW 325xi
The 235/35/18 will be smaller than the 225/40/18 in terms of height. I would suggest you just go with 225/40/18 all the way around.
07-06-2012, 01:52 PM
#10
Car: 2001 325i
just to close the matter, got new vredestein 225/40 and 235/40 tires and the rubbing doesnt occur anymore there is just enough spacing for when the car drops..
07-06-2012, 02:41 PM
#11
Car: 328i & 327i turbo
Just put one of these on your car and the fat chicks will stop asking for rides..
12-26-2012, 02:11 PM
#12
Car: 2006 M5
Can you check and make sure the spring isn't broken on that side?
12-26-2012, 05:06 PM
#13
Car: 90 325i, 84 rabbit
Is it springs or coilovers
12-26-2012, 06:54 PM
#14
Car: 2001 325i
the spring is chipped on the side now in process of looking for replacements
