Old 05-26-2012, 02:18 PM   #1
jay01_brown
OBSERVE
clutch pedal noise
been noticing a noise every time i engage the clutch, like a squeaking sound... as well, when i disengage i also hear a consistent noise.
throw out barring??
any help would be great
thx
jay01_brown is offline   Reply With Quote
Old 05-26-2012, 05:43 PM   #2
E36is
'OldSchool..'
E36is's Avatar
new clutch time.
Old 05-26-2012, 05:46 PM   #3
Ceeker
chances are if the release bearing is making noise the clutch may need replacing.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 05-27-2012, 01:51 PM   #4
jay01_brown
OBSERVE
uh oh! lol
if that is the case, what are my options as far as oem kits go?
i hear a lot of people talk about an m5 clutch/flywheels as a performance upgrade
Does anyone have any info on that?
Old 05-29-2012, 09:26 AM   #5
SiR
Vtec just kicked in
the squeaking is normal.
constant noise (like water running sound) not good
-||Old Crayons||-
Old 05-29-2012, 12:15 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Throwout bearing only makes noise when you push on the clutch. The noise you are hearing is likely the input shaft rumble common on e36's. Is the squeaking sound from the pedal or from the transmission?
Old 05-29-2012, 12:21 PM   #7
Not always true, it can be the throw out bearing, mine was, which is common problem for e36s. I had the same noise on mine. It rattles as the pressure plate is turning, but once pressed it the pressure stops the rattle.
Mine eventually disintegrated and I could no longer clutch in, had to get the car towed to StanceFactory for a clutch job.
There literally was no throw-out bearing left, it was in pieces when Mike got it apart. My clutch still had lots of life, but I replaced it while in there as it probably was the factory clutch.
Old 05-29-2012, 12:24 PM   #8
Originally Posted by jay01_brown View Post
uh oh! lol
Unless you plan on making lots of power, I would stick with OEM SACHS.
or if you want to upgrade an M3 flywheel + M3 clutch.
Old 05-29-2012, 03:35 PM   #9
Maple
Do you have the violin symphony like in this video ?
http://www.youtube.com/watch?v=n5ZO-...layer_embedded
If so, then it your throwout bearing. Either replace it or if you're on a budget the get a can on lithium grease and spray the TB.
Its simple, remove the slave cylinder and using a long straw spray lithium grease right all over TB, try not to get any on the clutch but its not a big deal.
Spray right on it
Make sure you dont press the clutch pedal while the slave is out.
I can guarantee that it'll work .
Maple is offline   Reply With Quote
