Old 05-15-2012, 10:57 PM   #1
Murchie
spark plugs for supercharged 328
Hey guys,
I'm looking to change the spark plugs on my newly acquired 328. What plugs do you guys recommend for a supercharged 328is? Or is stock good enough? Also what gap and torque specs? Thanks
Murchie is offline   Reply With Quote
Old 05-16-2012, 01:28 AM   #2
iverson03tj
iverson03tj's Avatar
i went with oem in my supercharger... no problem... i used ngk brand.. dont use bosch... i initially bought the bosch ones and the car started to act a little funny... rpm would drop sometimes... but it works amazingly with the ngk...
e39 M5 (s62)- Muffler Delete, Timmay Tips,
e30 325ic - Hard Top, Matte Black
e36 328is - (m52)AA S/c'd, M50 Mani, 3.23 LSD, M3 Brakes, Zimmer rotors, hps pads, Racing Dynamic Strut Bar, Depos, m3 Bumper, Intake, Spal fan, poly RTABs, Eibach Swaybars, Koni yellow, Mishimoto Rad, Silicone hose, Alumi T-housing, Depo w/LED Angels, LED tails, 12' Alpine Type R, Suede head liner, LTW Low rise spoiler
PREVIOUS CARS
92' 325is (m52) - M3 conversion AA S/c'd
'97 Euro Estroil E36 M3 Vert (S50B32)
Old 05-19-2012, 01:08 PM   #3
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
yeah people seem to swear by NGK for FI
Murchie you can always go with a Colder plug if you're getting pinging
Old 06-01-2012, 11:25 AM   #4
Lang75
220 Kph, E39 on Autobahn
I know with the Nissan Z cars the NGK's are sworn by. The issue with platinums is that they are not designed to run with very high compression or boosted engines. I haven't heard anything on the iridium plugs on boosted engines, but would recommend staying with the standard designed ones.
Lang75 is offline   Reply With Quote
Old 06-02-2012, 12:20 AM   #5
iverson03tj
im not sure but the only reason manufacturers use iridium is because its lasts longer.. which makes there cars less maintenance.... i hear copper is good??? again its words i heard... not proven facts
PREVIOUS CARS
Old 06-02-2012, 08:57 AM   #6
Lang75
When I bought my 328, it had these bosch plugs which had four prongs open centre, the size of the anodes and cathodes were the same as convetional ones as these were not platinum. I replaced mine with iridium after doing some research, and the engine was more responsive, ran smoother, i found myself shifting 500 rpm later under normal driving. So I will recommend them for a NA car, but as mentioned I can't comment on boosted applications.
Old 06-04-2012, 10:30 AM   #7
SiR
Vtec just kicked in
ngk bk6re
or bk7re if you want one step colder.
-||Old Crayons||-
Old 06-07-2012, 01:39 AM   #8
iverson03tj
http://store.bimmerworld.com/ngk-iri...ugs-p1267.aspx
PREVIOUS CARS
