Old 05-15-2012, 11:37 AM   #1
WlodeK84
whining noise between 700 and 1500 RPM
Hi Guys,
So I've had my 99 M3 for almost 2 months. I love it....no need to say more. recently I have had a noise happening after driving hard and braking hard I get a whining noise as I let go of the throttle and the revs drop. Does anyone else have this issue?
Any ideas on what may be the culprit? The car drive mint .......preforms unbelievably. Just trying to cover all my bases so I don't neglect a disaster.
Thanks,
here is a quick pick of my M3.
WlodeK84 is offline   Reply With Quote
Old 05-15-2012, 12:08 PM   #2
E36is
'OldSchool..'
E36is's Avatar
without a sound clip, could be anything.. alternator bearing, waterpump going, tensioner(s) going, could even be worn serp. belt.
Old 05-15-2012, 12:11 PM   #3
WlodeK84
Totally.
I will try to get a clip of the noise but to be honest you will never be able to tell even on HD. But I will give it a try.
I have changed the the two idler pulleys but it sounds like it is coming from under the intake manifold. Could it be the Drive Shaft center support bearing?
Old 05-15-2012, 01:02 PM   #4
Check your power steering fluid level (ATF). Good chance you're hearing a dry pump.
Old 05-16-2012, 01:14 AM   #5
WlodeK84
Thanks for the Tip. I will definitely get back to you on that.
Old 05-16-2012, 01:34 PM   #6
WlodeK84
So I feel like a Retard. It turns out that is exactly what it was.........topped up and noise is gone. Totally slipped my mind to check the Power Steering fluid.
Thanks Again.
Old 05-17-2012, 11:42 AM   #7
No problem, glad I could help save a trip to somewhere with labour bills.
