Go Back   maXbimmer Forums > Platinum maXbimmer Sponsors > StanceFactory
Old 04-25-2012, 08:49 PM   #1
kuntzie
can stance factory work some magic?
just dropped my car a couple weeks ago and bought a set of style 42s, did some custom powder coating too (17x 8 20mm)
anyhow
i want to run a 245/40 on the rear do to my upcomming large increase in power,
keep in mind i have another set of wheels for the track that arent such and agressive offest,
so my question is, can my fenders be pulled enough by you guys? im running 215/45s currently with no rub but some decent camber
1999 e46 sedan, hsd coilovers, 18" staggered style 5s in yellow, carbon fiber trim, other things and stuff
2001 pontiac grand prix turbo, 584whp/ 566wtq.. 5-speed swap, tilton triple disc clutch, air ride, 285/35/18s on the front traps 132mph in the 1/4
kuntzie is offline   Reply With Quote
Old 05-01-2012, 02:58 PM   #2
Most likely, yes. The only crippling point would be your rear spring rate, not sure what HSD specifies but you'll want at least 500lb/in linear to prevent rubbing after the pull. We sell replacement coilover springs also, if need be.
Give me a call for an appointment!
