01-06-2010, 03:36 PM
Car: E90 Race Car
Powerflex Bushings At RMP Motors!
We now are a Canadian Dealer for Powerflex Poly bushings!
Upgrade to Polyurathane bushings Prolonged tire life, Improved performance,
Increase safety, Greater cost-effectiveness
Are you noticing:
Imprecise handling? Uneven tire wear? Braking instability?
These are the common problems associated with soft, ageing, or failing rubber compound suspension bushes.
Please call or email with what bushings you may need, as we are making a large stock order soon!
Rocco
RMP Motors
01-13-2010, 01:48 PM
Car: E36 4D black M3
do they make a complet kit for E36's or just individual ?
PM me with info.
01-13-2010, 02:05 PM
Techno Viking
Car: S54 E36 M3
PM me with info.
I'd like to know this too, along with the price for an e36 M3.
01-13-2010, 04:29 PM
Car: E90 Race Car
I will check on kits!
As soon as I recieve the order I will post up Prices in Canadian Dollars
01-14-2010, 03:19 PM
thanks
01-14-2010, 04:35 PM
Car: E39 540i
Damn, I just bought some for the thrust links on my E39 540 on the internet and would rather have supported a local shop.
Anyway, I would also like to know prices for the rest of the bushings, as well as a ballpark installation price when you get a chance.
1998 E39 540i 6 Speed
01-15-2010, 01:53 PM
Car: BMW 540i
Hustler you do know you have to lube these bushings every now and then
E39 540i Sport
01-15-2010, 02:12 PM
Car: E39 540i
Oh yeah, I have a similar product in my Jeep. Any poly bushings seems to transmit just a little more vibration, but in my Jeep allow better articulation and suspension movement over the factory solid rubber ones, and in my 540i should last a good deal longer than the stock units. I used my own grease with the Jeep ones - that was a mistake. Use copper grease, and you're golden.
In fact,
I'm going to take a big leap here,
I swear by polyurethane bushings.
01-15-2010, 03:04 PM
Car: BMW 540i
How often do you have to grease them?
E39 540i Sport
01-15-2010, 03:28 PM
#10
Car: E39 540i
My current set in the Jeep mostly have grease zerks. I do those whenever I am underneath (another high maintenance vehicle). The ones without tend to go a year or so, but could probably last longer in a car with a) less suspension articulation, and b) less immersion in water and general filth.
If it helps, I have never heard them squeaking.
01-15-2010, 03:36 PM
#11
Car: MK6 GTi
^so what are the drawbacks of never greasing them? accelerated wear? or is it just squeaks
01-15-2010, 07:48 PM
#12
Car: E39 540i
I suspect they would become squeaky and wear faster, I dont know for sure because I have never left them that long.
They definitely press more easily than conventional bushings. The hardest part of greasing them is getting the bolts apart, unlike rubber bushings that are a bitch to get out sometimes.
01-15-2010, 09:57 PM
#13
Car: 325i, 335xi
I find that you pretty much have to grease them at least once a year. I do it in the spring, because the grease seems to be washed out by winter usage. On my anti-roll bar, I didn't grease them for a couple of years when I was on the west coast and it seemed to actually wear out the bar a bit. On a street-driven car, I would only put them on the anti-roll bars because they're readily accessible and R&R does not mess up your alignment (not a problem, however, if you've got grease fittings).
01-18-2010, 07:27 PM
#14
Car: E90 Race Car
E46 and E36 Trailing arm Bushing sets IN STOCK!!
They give alot better straight line stability, and put the power down better!
Get them replaced, the OEM ones wear out quick, making rear tires wear quickly, especially on M cars.
As long as they are lubricated properly when installed, they last a long time without squeaking!
01-18-2010, 11:05 PM
#15
Price?
