04-07-2012, 01:31 AM
#1
Car: 97 328is
E36 steering rack info needed!
My 328is is in need of a steering rack. I was wondering what I can fit in there in terms of other models such as z3,e30,e46 etc.. and what would be the advantage/disadvantage of going with them. Also r rebuild racks any good in terms of cost/quality. Any info is greatly appreciated.
Thanks.
[| aFe CAI || 3.38 LSD || M50 SWAP || SuperSprint Exhaust || H&R + Bilstein Sports |]
04-07-2012, 07:36 AM
#2
Over 9 F**KING THOUSAND!!
Car: '91 325iS | '96 332i
Non m and 96-99 m3 are same, 95 m3 slightly quicker ratio, z3 less turns due to less travel. Stay away from e30 racks, they require modification and are a downgrade. E46 racks dont fit to my knowledge.
04-07-2012, 08:49 AM
#3
Car: 97 328is
Awesome.. thnx for the info
04-07-2012, 11:46 AM
#4
Car: 330ci SC, M5 Touring
If E46 rack fits on E30, has to fit the E36!  They are almost identical in design. 330's after 9.01 had the 3.0 turn ratio that was shorter then other E46's...
04-07-2012, 11:50 AM
#5
Car: 97 328is
can you elaborate more on the ratio and what it does?
04-07-2012, 11:57 AM
#6
Pretty much means how many turns of the steering wheel you need to go from full left to full right. The smaller the #, the more responsive the steering is!
04-07-2012, 12:24 PM
#7
Car: 97 328is
you got any i can use???
04-07-2012, 01:02 PM
#8
Car: 84 S52 e30/330ix e46
Ya e46 racks should fit, I believe I've also seen modification to use z4m racks if you want to go that far :p
Z3/02+e46.330/e36m are ideal in that order IMO from when I was looking around
04-07-2012, 01:49 PM
#9
Car: 97 328is
thnx for the info. now i just need to find one
04-07-2012, 02:37 PM
#10
You're looking used/cost effective? Or rebuilt?
04-07-2012, 03:29 PM
#11
Car: 97 328is
i was considering rebuilt but wasnt sure how much it would cost me
04-07-2012, 03:41 PM
#12
Learn something new everyday.
04-07-2012, 04:25 PM
#13
Car: '90 328i
He's deff right about that, this is a stock e30 rack vs an 04 330 (e46) rack going into my e30, courtesy of Mr Eurostyle himself. Very similar in design, veeery different on the road.
04-09-2012, 10:16 AM
#14
Vtec just kicked in
Car: 99 S52
e46 racks bolt right in.
even z4 fits(just).
even your stock lines bolt right up .
oem homologation ftw
and the rack ratio means a heck of a lot more than the turns to lock. you want to concentrate on the ratio if you are looking to change things up.
example above the later model 330 rack have a 13:1 ratio. (which is actually faster than the e46 m3 rack which is around 14.5:1 iirc)
You can find good shape used e46 racks at a few of the bmw parts guys around these parts.
-||Old Crayons||-
04-10-2012, 01:56 PM
#15
Car: 97 328is
even z4 fits(just).
thnx for the info.. i am actually shopping around for them.. i called a few places but have not been able to get a proper response.. if anyone has a steering rack from an e46 late model 330 or m3 or even e36 pls let me knw.
