Old 03-27-2012, 01:18 PM   #1
WlodeK84
E36 Short Shifter install
Anyone know how to change a shifter in a E36 Coupe?
I've got a 99 M3 and Need to swap out the bushings for the Shifter lever (very sloppy). I figure great opportunity for a short shifter kit. I have read that the exhaust has to be removed etc. can someone confirm. Is there a way to do it from inside the car? Might be a stupid question but I am not sure.
Let me know
WlodeK84 is offline   Reply With Quote
Old 03-27-2012, 01:21 PM   #2
Can't be done from inside only.
Probably easier to take it to shop if you don't know what your doing.
There are several parts that need to be refreshed to remove the sloppiness.
Here is a DIY if you think you can tackle it yourself:
http://www.pelicanparts.com/bmw/tech...hort_Shift.htm
Old 03-27-2012, 01:43 PM   #3
WlodeK84
Thanks for that........it helps out a bit. Any idea how many hours of labour a shop would charge for such an upgrade?
Old 03-27-2012, 02:39 PM   #4
limenuke
Jay from Stance Factory might still nice enough to do the E60 Short shifter install with bushing refresh for 200 flat!
limenuke is offline   Reply With Quote
Old 03-27-2012, 02:40 PM   #5
Not sure, I would guess around 1-2 hours.
Stance Factory had this OEM SSK special. Included a new lever, and other parts for refreshing for $200+tax installed.
http://www.maxbimmer.com/forums/showthread.php?t=147542
Old 03-27-2012, 03:47 PM   #6
tehskeo
CEL Magnet
tehskeo's Avatar
Took me about two hours and I am not a mechanic. If you want to DIY I would highly recommend a lift.
I installed Richie's SSK: http://www.youtube.com/watch?v=UrQgNWz5-BQ. It was cheap and it is very short and notchy. A weighted knob is recommended.
tehskeo is offline   Reply With Quote
Old 03-27-2012, 06:52 PM   #7
hawgripper
jay did mine last year when the clutch was done. I replaced every bushing,washer and pin I could and it shifts butter smooth. I also added an acs weighted knob.
If you can get it for a couple of hundred installed that's a deal..
The list starts here: Depo headlights w 8000k hid's,/CCFL's , smoked tails, corners and BBS RC041's/042's, Vogtland junior cup kit.
Lightweight flywheel ,clutch and SSK are in.....
hawgripper is offline   Reply With Quote
Old 03-28-2012, 12:24 AM   #8
gotcurry
burble city
gotcurry's Avatar
It would be nice if stance factory still has the 200 deal. I would be down for a ssk install.
gotcurry is offline   Reply With Quote
Old 03-28-2012, 12:02 PM   #9
jon.e
jon.e's Avatar
I did mine on my own. I never lifted the car. Did the entire job from the interior of the car. I would recommend jacking it up and getting underneath to do it, it will make ur life easier getting that little clamp on. But it took me about an hour an half.
E36 s52 powered 328i - track car
2002 Honda civic si veloz- DD
jon.e is offline   Reply With Quote
Old 03-28-2012, 12:38 PM   #10
dcramer
Stance factory uses the standard shifter for the e90, there is actually a short shift kit for the e90 which would shorten the shift up even more. P/N 25117546373
Has anyone tried this shifter?
Dave
Old 03-28-2012, 12:47 PM   #11
WlodeK84
Great Video. You don't happen to have one of the installation?
Old 03-28-2012, 01:02 PM   #12
SiR
Vtec just kicked in
you dont HAVE to remove the exhaust either.
its tight but do able
-||Old Crayons||-
Old 03-29-2012, 12:34 AM   #13
bimmer325
make sure you wrap the #9 linkage with a heavy solder and wrap it with tapes. this will help the throw feeling and nicer shifting. just a cheap affordable tricks.
www.drive-more-fix-less.com
bimmer325 is offline   Reply With Quote
