05-12-2012, 08:12 AM
#46
Car: BMW 318is
Big big order made this week!!
Look out for a post filled with goodies in the next few weeks!!
05-16-2012, 03:15 PM
#47
Car: BMW 318is
May 16,2012
While waiting for a HUGE shipment from ECS.. I kept thinking about what I was going to do about the famous brake booster.. At first, the booster was gonna be moved over 1/2 inch blah blah. After researching, I found out that a AUDI A4 brake booster could be used by shortening the push rod and modifying the E30 clevis. Good news for me is that my buddy had just what I needed.. Mint booster with a MC and the res. Also went to local scrap yard and found this beautiful VDO gauges in a Audi Quattro. They came surrounded by a wood panel. That will be changed. Got all three for 5$. As soon as the ECS shipment arrives, pictures will follow....
05-16-2012, 03:49 PM
#48
Car: e36 M52 330i
have you tried putting the engine in the car? My brother did, and the oem headers were hitting the subframe. He needed to get the longtubes to make it fit...
Good progress though! should be a solid engine
05-16-2012, 03:53 PM
#49
Car: BMW 318is
I heard that the long tubes hit the subframe :/ The oem headers dont seem long enough to cause a problem..
05-16-2012, 04:37 PM
#50
Car: Ugly M50 swapped E30
Yeh, I'm using stock M50 manifolds and they're great.
Originally Posted by 411
05-16-2012, 04:51 PM
#51
Car: BMW 318is
Are the M50 and M52 headers exactly the same?
05-16-2012, 05:11 PM
#52
Car: e36 M52 330i
Really eh? Cuz the flange on Chris' M50 manifold was hitting his subframe.... maybe it's because he was running AKG mounts that lowered the engine?
05-16-2012, 05:26 PM
#53
Car: BMW 318is
Im planning on using AKG mounts too but im not sure if the M50 and the M52 headers are the same... If the flange does touch the subframe, ill either cut it off and make the header a one piece with the downpipe. If not ill just buy the long tubes
05-16-2012, 10:21 PM
#54
Im on E28 525i mounts and i have enough room to mate a flange to the manifold and gracefully arch it down along the firewall/transtunnel.
05-17-2012, 02:30 PM
#55
Car: BMW 318is
Well Max I hope that I have the same luck as you
05-31-2012, 12:14 AM
#56
Car: BMW 318is
05-31-2012, 12:29 AM
#57
Baller.
05-31-2012, 01:40 PM
#58
Car: 1990 325i
Looking at your subframe bushings, I bought the same ones. But I guess my sticker fell off in shipping. I had no clue what way to install them so I put them upside down(smaller side up top) and when I saw this I panicked and called AGK. He said it didn't matter. It will help you offset your camber if you raise the subframe aprox 5mm.
Just I'm not sure how the diff will line up now. Haven't installed that yet.
90 325i 4dr Winter fun
90 325i 2dr Summer/track car
87 325i 4dr Parts
06-02-2012, 03:18 PM
#59
Car: BMW 318is
Sorry the pic made you panic. I dont think you'd have a problem with 5mm. Best of luck to you and let me know how it goes.
06-06-2012, 08:02 PM
#60
Car: BMW 318is
June 6,2012
Well the ECS shipment arrived and got a lot of shift related parts with a few drive shaft parts..
Shifter Carrier
M Oil Cap
Magnetic Drain Plug
Fan Delete Nut
Teflon Bushings
Dust Covers
E34 Throttle Cable
Still waiting for the UUC DSSR which is back ordered and will be sent to me ASAP
Also got a E30 CSB and my buddy made me a Engine Ground. Ignore the transmission mounts. I got them but then decided to get AKG mounts soon.
After seeing one of my buddies valve cover on his VR6, I took mine off and painted it with a VHT High Heat Wrinkle. I really like the out come..
As she sits right now
