Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 04-16-2012, 10:14 PM   #31
SamE30e
SamE30e's Avatar
Sorry Bruno, you lost me at JB weld.
Downing Atlanta kit would have been a great idea, and probably cost the same.
85 325 - Turbo M52B28.
Old 04-16-2012, 11:05 PM   #32
Ok fine, he'll use devcon...
And isn't the Downing/Atlanta kit close to $4k new?
I'd imagine you might be able to find a used one for $1500-$2000k but they don't pop up for sale very often.
Old 04-17-2012, 08:26 AM   #33
BMe30
all by chance...
BMe30's Avatar
Im actually using QuikAluminum its the stick where you cut off what you need and knead then apply. Ive read a lot of great reviews and applications similar to my needs.
Gone but not forgotten
Old 04-17-2012, 09:19 AM   #34
I was just kidding around. I don't really care what you use. If it works... it works!
Old 04-17-2012, 10:28 AM   #35
BMe30
all by chance...
BMe30's Avatar
All good! I didnt take any of it the wrong way at all.
Im pretty easy going
Old 04-17-2012, 09:41 PM   #36
BMe30
all by chance...
BMe30's Avatar
look what i got today :D
Wemoto filters
slowly getting there
Old 04-18-2012, 09:33 AM   #37
SamE30e
SamE30e's Avatar
Aren't you in engineering?
Bruno, mock it up, get someone to weld it. There's plenty of shops that will do it for you.
Old 04-18-2012, 10:03 AM   #38
BMe30
all by chance...
BMe30's Avatar
Im not too familiar with aluminum welding.. Would the weld warp or distort some of the tb housing? Does aluminum welding generate more or less heat as steel welds?
Old 04-18-2012, 10:19 AM   #39
SamE30e
SamE30e's Avatar
Well, they don't look like they are that lined up anyways. So it wouldn't affect performance even if they did. But no, it shouldn't. Aluminums general melting point is 660 degrees celcius, Steel is around 1400-1500 celcius depending on the type.
I would get a piece of tube welded onto the intake mani side. Or, get a flange fabbed up to fit the itb's properly.
Old 04-18-2012, 10:31 AM   #40
BMe30
all by chance...
BMe30's Avatar
Oh about that... Im getting a friend of mine who works at a machine shop to machine the upper intake adapter to match the O.D. Of the tb and make it level. I have to do it this way to bolt the upper intake to the lower intake... The itbs interfere with the nuts to tighten. I had the same issue in V1.0
The quick aluminum is to fill the holes exposed by the injectors removed from the itbs and then add nipples for the catch can vac lines
Old 04-18-2012, 11:03 AM   #41
I'm going to ignore this because it seems as though you were under the impression that Bruno was going to use JB Weld to join the TB to the upper manifold. As he just mentioned, he's using the epoxy to do something like this...
Old 04-18-2012, 11:07 AM   #42
BMe30
all by chance...
BMe30's Avatar
Is that yours?
Old 04-18-2012, 11:09 AM   #43
Is that yours?
No lol, I pulled it from the link I posted on pg1.
I'm going to be using the motor I pull when I swap in my stroker to do the ITB build.
Old 04-18-2012, 11:20 AM   #44
BMe30
all by chance...
BMe30's Avatar
Awesome!
Old 04-18-2012, 08:22 PM   #45
SamE30e
SamE30e's Avatar
I stand by my statement. I would get a manifold fab'd up. Might see a bit better gain.
