Old 03-12-2012, 12:09 PM   #1
dcramer
M3 brake pedal height
I've been struggling with a low pedal for a while, and had a look at the resting height of my pedal. It is noticeably lower than the clutch pedal. Is this normal? Mine is about an inch lower.
Dave
Old 03-29-2012, 11:51 AM   #2
dcramer
anyone ?
Old 03-29-2012, 12:24 PM   #3
Try bleeding your brakes there could be air in the system causing a low pedal.
As for while the pedal is at rest, I have not noticed mine being much lower. I'll take a closer look at it this evening.
Dare I squeeze
Old 03-29-2012, 03:19 PM   #4
dcramer
I've bled them a number of times
I'd appreciate if you could look at yours. If your clutch and brake are at the same height this would explain a lot.
Dave
