Old 03-29-2012, 06:39 PM   #106
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Originally Posted by defaultName View Post
dangerous?
There's two bolts. What's the worst that can happen, right?
Grow up and move on.
Old 04-02-2012, 09:01 PM   #107
defaultName
So Scott came by on Friday and we actually managed to swap in the Z3 steering rack fairly easily.
Everything went pretty smoothly and there looked to be barely any binding in the steering knuckle. We didn't have time to actually drive the car that day so it wasn't until Sunday that I actually was able to pull it out of the garage.
Overall I'm pretty happy with the way it's sitting although I seriously need to put my new wheels on!
The problem's started happening when I drove it. I didn't really have an issue with binding so much as the car pulling violently left and right. It fells as if someone is jerking on the steering wheel. I would turn the steering wheel very slightly and then it would continue to turn on its own until it locks
I put the car back in the garage and tried to grind down the steering knuckle but it didn't feel or look like it was binding very much so I wasn't sure how much to really remove. I drove the car again and it didn't feel much better at all.
I'm really not sure what could be causing this. Would a binding steering knuckle cause the car to pull from side to side, because I thought it would make it harder to turn?
I even tried to check if my tie rods were touching my wheel but there seems to be enough room. Power steering has been deleted as well.
Any ideas?
Old 04-02-2012, 09:22 PM   #108
Ceeker
Did you double check alignment? toe out can definitely affect steering. I would lube the shit out of the knuckle and then work it in and drive to see if it changes. I've had binding steering knuckes - typically occurs from car sitting for a while. We use to lube those periodically to keep them free. what tires are you running stock or wider? that can also have an effect. Are you sure the rack is good. A worn shaft can cause binding through it's turn cycle.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 04-02-2012, 09:24 PM   #109
dble Trouble
TAKE IT TO THE TRACK
dble Trouble's Avatar
Alignment....you're toe is probably out something drastic!
Old 04-03-2012, 04:45 PM   #110
defaultName
Can bad alignment really cause the car to behave like I described? It seems a little extreme.
I guess I can try to make my wheels more even or toe in a little and if that solves the problem then I'll know for sure. I can get a proper alignment when the car is a little more driveable.
By the way the car has stock 14" weaves and the rack is brand new so I'm hoping it's not the rack itself.
Old 04-03-2012, 04:50 PM   #111
Yes, I wouldn't change a rack without doing an alignment after.
Old 04-03-2012, 05:21 PM   #112
defaultName
I did plan on doing an alignment but I'm kind of scared to drive the car in this condition to go and get one!
I just find it hard to believe that poor alignment can cause this.
Old 04-03-2012, 06:15 PM   #113
I'm wondering if this has something to do with your power steering delete...
How much fluid is in there circulating thought?
Old 04-03-2012, 07:31 PM   #114
defaultName
I'm starting to think so too.
The rack came pretty much full of fluid and I didn't drain any aside from whatever spilled out when installing the delete.
The problem is that I can't find a definitive answer on how much should be in there.
I PM'd the guy I bought it from on r3v to ask.
Old 04-04-2012, 12:16 AM   #115
dble Trouble
You would be shocked how much an out of adjustment alignment can cause the car to pull and jerk violently over broken or uneven pavement. That being said, why oh why did you remove your power steering and buy a brand new rack? That just doesn't compute to me? What am I missing Kevin?
Old 04-09-2012, 12:33 AM   #116
E30M42cab
E30M42cab's Avatar
You weren't supposed to drive it until you fixed that toe out! Remember I said "it's toed out, gotta take the wheels off and turn the tie rods in at least two turns each". Yea you do. You really should do that, and remember that the shackles on the tie rods were never tightened either.
Old 04-09-2012, 07:04 AM   #117
defaultName
I turned them in two turns each, then tightened the clamps, then drove it, then got scared and parked it.
Then I turned them in two more turns each, drove it and no change at all.
I'm going for an alignment tomorrow and new power steering parts will be ordered just in case it's an issue with the delete.
Old 04-09-2012, 08:34 AM   #118
Ceeker
These cars are quite sensitive - believe it or not; if you are in tune with the car you can feel everything and notice the slightest changes. if after the alignment the condition doesn't change- which I can't imagine it wouldn't. Wait ti'll you get wider rims and tires for it and then see what your car will be doing. :-) the proper way to do the alignment on these car is to have the passenger and drivers side weighted to mimic having yourself and a passenger in the car. Bmw used sand bags when doing the alignment. My bmw tech friend use to toe in the tie rods slightly to make the car more responsive (stock rack of course)
Old 04-09-2012, 09:28 AM   #119
Toe in actually gives slower steering response, which is why toe in increases straight line stability. Toe out is what gives you quicker steering response.
One way to really check out what's up with your steering Kevin would be to turn in your tie rods so that you know both wheels are for sure toed in. Then your steering should try and maintain the car in a straight line to some degree. It still might pull right or left, but it shouldn't send your steering wheel to full lock.
Old 04-09-2012, 09:54 AM   #120
richie_s999
I had a similar think happen in my e30 when I swapped the rack years ago, mine was binding in the steering knuckle, Try adjusting it, and give it a cleaning and grease. The rubber rag joint makes it a non solid joint to take up play but it it's worn or not sitting properly can also cause binding to come and go.
Hope it helps and the description makes sense
