Old 03-15-2012, 08:09 AM   #31
Originally Posted by defaultName View Post
This.
Timeline always has to have an "ish" when working on E30's
^ lol
That happened to me last night. I went to swap on my summer tires and I decided that while I had the front wheels off I'd swap in my new Koni inserts (old ones were destroyed). I got to unbolt the swaybar link tab from the control arm... stud shears off like butter. Oh well I can live without my front sway bar for a day or two... I'll just take off the sway bar link so it's not flopping around and rubbing against anything... nut is seized on the link pretty good and the flats for the thin 16mm spanner aren't doing shit to support me... I try clamping down with a vice grip to hold it... no luck... at this point the sway bar link is more or less ruined... So I just cut it off with the angle grinder.
Long story short I went out at 7pm thinking it would be an hour and half-ish maybe 2-ish hour job... I finished at midnight.
Old 03-15-2012, 08:44 PM   #32
Love it Bullet Ride. That's some classic E30 shit.
Put it in the thread... http://www.maxbimmer.com/forums/show...115069&page=12
Old 03-15-2012, 08:58 PM   #33
cormier
cormier's Avatar
^^ lmao that story sounds pretty familiar
Old 03-16-2012, 07:21 AM   #34
defaultName
Originally Posted by E30M42cab View Post
We'll get the whole motherf-er done tomorrow night in an hour... ish.
Unfortunately this didn't happen.
About 3 hours later and the tie rods STILL WOULDN'T COME OFF!!!
[opens a new tab to search for a Z3 rack...]
Old 03-16-2012, 08:57 AM   #35
Are you guys still trying to remove the ends? Or are you trying to remove the whole tie rod assembly from the steering rack now? It shouldn't be hard to remove the end that threads into the steering rack because it's protected by the boot, and when your steering rack takes a shit it self lubricates...
Old 03-16-2012, 10:16 AM   #36
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
yeah, just the outer end... that's all he ordered. We figured we'd give it a few days soaking in PB Blaster, then hit with a flame and crank it off. Didn't happen. Anyways, the suspension is all back in, new ball joints and M3 offset lolly's are in (funny story). we just need to take care of this rack, bleed the brakes and GET SOME RUBBER ON THOSE et13's!!!!!!!!!!!!
Grow up and move on.
Old 03-16-2012, 06:40 PM   #37
SamE30e
SamE30e's Avatar
Heat heat heat heat heat...
85 325 - Turbo M52B28.
Old 03-16-2012, 08:09 PM   #38
E30M42cab
E30M42cab's Avatar
yeah, we've heated the shit out of them, don't worry. Propane only heats so well.
Saws-all is next.
Old 03-17-2012, 11:33 AM   #39
defaultName
New parts on order.
New Z3 rack, new hardware, and a power steering delete because I don't even know where to begin with that leaky pile of garbage!
No more wasting time with used, seized, original bullshit...
Old 03-17-2012, 12:38 PM   #40
MAPP equivalent gas works a little better than propane.. not much, but a little, fyi.
Old 03-17-2012, 09:06 PM   #41
SamE30e
SamE30e's Avatar
Don't delete the power steering. Just fix it, probably needs crush washers.
Old 03-18-2012, 07:25 AM   #42
defaultName
I'm going to try it out for a while to see how it goes. It's leaking from a few places, one of them being the bottom of the reservoir.
I won't remove the pump or anything until I drive around for a bit and am satisfied that I can live with it.
It's really just a temporary fix so I don't have to deal with power steering leaks for now.
Old 03-18-2012, 01:34 PM   #43
SamE30e
SamE30e's Avatar
Easy fix! Don't conform, it's not Fuhraze
Old 03-18-2012, 03:08 PM   #44
defaultName
it's not Fuhraze
Not yet, but it will be soon!
...just kidding.
I have no intention of butchering this car in the hopes it will magically become a race car. But if I can kill two birds with one stone then why not?
Old 03-18-2012, 08:39 PM   #45
An Oxygen Acetylene Torch and a pipe wrench and that sucker is coming off.
Otherwise it's best to just buy the complete tie rod assemblies. (Aren't they like $60 each end complete?)
