Old 03-08-2012, 02:19 PM   #1
wrx_
i'd like to borrow RTAB removal tool in GTA
anyone? thanks
wrx_ is offline   Reply With Quote
Old 03-12-2012, 12:07 PM   #2
dcramer
make one, pipe caps and threaded rod.
FYI, removal isn't the problem, pressing them back in is. To remove them just cut them out.
Old 03-13-2012, 11:44 AM   #3
wrx_
thanks man, i'll google how to make one
Old 03-13-2012, 04:20 PM   #4
Vrbovsky
pod stromom
dont bother with stock rtab and making tools! Just buy poly bushings, they press right in.
I've done both and I can tell you get the poly urithane. for the extra 50$ the time and effort you save are well worth it!!!
Vrbovsky is offline   Reply With Quote
Old 03-13-2012, 05:12 PM   #5
InfiniteDice
12 Years with the E30
InfiniteDice's Avatar
That's right... pull the subframe ... apply propane torch to metal surrounding the tab, wait for yummy sizzling bacon sound... use any method desired to hammer, pull or yank them out...
Are they grouchy? apply more heat. Repeat.
You can do it with the subframe on the car... to do this effectively you do need a tool, or make a tool.
Old 03-13-2012, 07:34 PM   #6
iverson03tj
Yupp mines are poly too... to take them off i used a drill with a round bit (deep enough to go atleast half way) and cut out the middle.
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
Old 03-13-2012, 07:55 PM   #7
wrx_
do i need limiters for poly rtabs?
what is a good place to buy them?
Old 03-13-2012, 09:19 PM   #8
doogee
Stance is Gay.
doogee's Avatar
I'd personally go with OEM mounts. Poly starts squeaking after a while.
Also, it is impossible to use limiters with poly. They already completely limit the trailing arms movement. Which is a bad thing actually.
Dakar M3 Track Build Thread
Old 03-14-2012, 05:46 PM   #9
sb_600
sb_600's Avatar
Despite what is mentioned above, if you still want poly bushings, mine are for sale.
Shawn
Old 03-14-2012, 09:13 PM   #10
Judith48
I used a drill with a round bit
Judith48 is offline   Reply With Quote
Old 03-14-2012, 09:15 PM   #11
dcramer
poly is not advised, yes they are easy to put in, but the joint moves in more than one plane
Old 03-15-2012, 08:21 PM   #12
wrx_
i've done some research and decided to go for the OEM ones with limiters. thanks everyone for your input.
Old 03-16-2012, 11:14 AM   #13
Renboy
I made a tool that you can borrow. You'll have to come to Guelph for it though.
