Old 01-19-2012, 07:27 PM   #1
reezer
Engine problems in freezing temperatures
I have a 1994 320i. When the temperature gets to about -5c the car starts and idles fine but about a mile down the road it starts to jerk like it is misfiring. It goes away after the car gets up to normal operating temperature. When the temperature gets below -10c the car either won't start or it will fire up and then spurt and sputter until it dies. In both cases black smoke will come out the tailpipe if I press the accelerator quickly. This goes away after the car is up to temp. The car works perfectly fine in the spring, summer and fall. Last year I put new plugs in it to get it to pass etest. I have also checked the coolant temperature sensor with my ohm meter and it tests fine. I also ran some fuel injector cleaner. To me, it seems like it's not getting the right air/fuel mixture. Does anyone else have any idea's? This is really perplexing and annoying and I want it fixed. The car is really not worth spending much money on and if I could find out what the problem is, I know I could just fix it myself. I have checked everywhere on the internet and I can't find an answer.
Help please
reezer is offline   Reply With Quote
Old 01-19-2012, 07:38 PM   #2
noodles101
ΛΦΕ
noodles101's Avatar
i dont know about your car shutting by itself..
but my e36 idles kinda rough if its really cold out..but goes away after min or two
how long do you usually warm up your car for?
Old 01-19-2012, 08:10 PM   #3
Steve30
Techno Viking
Steve30's Avatar
O2 sensors? dirty MAF? coils? that's probably where I'd start looking.
E36 ///M3 S54
???whp E30 coming soon.
Steve30 is online now   Reply With Quote
Old 01-19-2012, 08:14 PM   #4
reezer
I read in bentley guide that o2 sensor doesn't affect startup of car. MAF, haven't checked. How can I verify the coils?
I let the car warmup for 5 min. But on really cold days it won't start at all.
Old 01-19-2012, 08:16 PM   #5
noodles101
ΛΦΕ
noodles101's Avatar
weak battery? alternator?
Old 01-19-2012, 08:24 PM   #6
reezer
Battery is good. It was new last year. And just to make sure, I tried jumpstarting it as well.
Old 01-19-2012, 08:28 PM   #7
noodles101
ΛΦΕ
noodles101's Avatar
what weight engine oil are u using?
i dont think it reaaally matters..but worth a try
Old 01-19-2012, 11:19 PM   #8
reezer
5w30
Old 01-19-2012, 11:42 PM   #9
Blackedout95
Could also check the ICV, Fuel Regulator and yes the O2 as well.
The black smoke indicates richness, I suspect you may have multiple issue going on. Go pay the man and get it scanned, value your time.
E46
Old 01-20-2012, 06:58 AM   #10
325isdan
Search "Stomp Test"
Will tell you how to pull any codes your car is throwing. It is very easy to do.
325isdan is offline   Reply With Quote
Old 01-20-2012, 10:18 AM   #11
BigD
the misanthropist
BigD's Avatar
That's a tough one... I agree with Blackedout, it's too much fuel. Find a used MAF to try. Also try resetting the computer (unplug the battery for a few seconds).
Old 01-20-2012, 10:44 AM   #12
sb_600
sb_600's Avatar
Could be a coil that has come condensation in it.
Check all your spark plug holes to make sure they're clean.
I was having the same problem in my e46, but it ended up being the spark plugs.
GL!
Shawn
Old 01-20-2012, 05:44 PM   #13
325isdan
DO the "Stomp Test" first then try everything else.
Old 01-25-2012, 04:51 PM   #14
5style
Hatters gon Hatt
5style's Avatar
sounds like you have a case of the maintenance! My m50 needed the following to bring it back to proper health, similar issues.
New O2 (obd1)
removal of maf, and cleaning ! brake cleaning fluid, fully dry
intake boot checked for cracks and cleaned
vacuum lines replaced
icv cleaned
new spark plugs
Throttlebody cleaned spotless
intake mani cleaned out 100% no more grime
Results, rock steady idle @ 560-600rpm, no stuttering, no jittering, starts up super easy in minus 10+
Costs: peanuts
